Sherwood Newcastle a965 7 channel amp
mdk5068
For sale is a brand new Sherwood Newcastle a965 7 channel amp. This is Shurwood's premier amp, the highest it makes. The nice thing about this guy is it has 7 mono blocks in it. 300 watts to one speakers is a beautiful beautiful thing. It is a 1050 Watt amp.
Retails for 1400, asking 700 - buyer pays shipping. I have receipt.
In Philadelphia (PA), New York (NY), or State college (PA)
Buyer pays shipping if necessary.
The A-965 is a 7-channel, 80-pound, independent main amp designed specifically for low impedance loads. With a power supply that contains two huge toroidal power transformers and the capability to unleash greater than a kilowatt of output power the A-965 could easily be used as a poster boy for the concept of High Current. But there is more to this amp than brute force. Each channel, from gold-plated input to heavy duty output, is built on a separate circuit board as an independent mono block, a design which minimizes cross-talk (and facilitates repair in the unlikely event that should become necessary). The discrete circuitry utilizes PNP differential input, Darlington current driver and parallel, pure-complementary, push-pull output. The results? The A-965 has the delicacy to limit its Intermodulation Distorion to only 7 parts in 100,000 (0.007% IMD) yet with all channels driven, the A-965 delivers 160 Watts x 7 at any combination of frequencies between 20 Hz and 20 kHz with less than 0.09% THD.
Designed for Low Impedance Loads
All-Channels-Driven Power 20 Hz-20kHz
100 Watts per channel (x 7) into
8 ohms
160 Watts per channel (x 7) into
4 ohms
THD <0.02% from 20 Hz-20 kHz,
8 ohms
THD <0.09% from 20 Hz-20 kHz,
4 ohms
2 Toroidal Power Transformers
7 Separate Discrete Amplifier Modules Built as 7 Separate Monoblock Amplifiers
Totally Discrete Amplifier Stage for All Channels
Gold Plated Inputs
Heavy-Duty Speaker Binding Posts compatible with bare wire, banana plugs and spade lugs
Remote turn-on via 12-Volt external input
Aluminum Front Panel
Amplifier Features
Dynamic Headroom, 8 ohms, 1.5 dB
Dynamic Power (EIA Standard Rating)
300 watts per channel, 4 ohms
480 watts per channel, 2 ohms
PS - Please no dumbass posts like last time
8 ohms
4 ohms
8 ohms
4 ohms
Gold Plated Inputs
Amplifier Features
Bulls make money.
Bears make money.
Pigs get slaughtered.
You, my friend, are the bacon.
Bears make money.
