Incorporating JL Car Audio into Home Theater
Cpyder
In my car, I'm running a set of SR6500s and 2 JL Audio 6w3v3s in the cabin. I cannot get over how fast and crisp the bass is. It doesn't hit the real real deep lows but I find big subwoofers to detract from SQ in most setups.
My question is - Would it be a good idea to run two of the w3s off two channels of my Marantz SR5003 along with two more channels pushing my LSi9s? I would build a custom enclosure to manufacturer's specs and finish with leather so it could look A okay. The room is fairly small. Is it worth a shot?
I figure it could be done for around $250.
Comments? Insults?
Thanks!
http://mobile.jlaudio.com/products_subs.php?series_id=29
Comments? Insults?
Thanks!
Post edited by Cpyder on
I think for $250 your money would be better spent on an HT sub....
But that's just my opinion.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »I think for $250 your money would be better spent on an HT sub....
+1, I haven't much luck in the past trying to "convert" Car Audio into HT equipment. $250 could get you a decent HT sub that will more than likely outperform the JL's. Leave the car gear in your car, just my $.02.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
Car gear is not meant to be used in a building. They are built for massive handling and harsh conditions. They are not necessarily designed for the best sound quality indoors. I've tried to convert some but it's just not economical, that and it didn't sound very good at all.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Thanks everyone for the input. Maybe I'll just throw a little more cash at the project and pick up a MicroPro 1000 refurb from Polk Direct.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390075575849&ssPageName=STRK:MEWAX:IT#ht_2961wt_838 -
Youre definitely going to have to post a thread regarding that MicroPro 1k. I've had my eye on it and someone else posted a thread on it, but not too much to read from. I've heard its a real musical sub, very tight, accurate and fast. I've got a small room so let us know how big the room is that you'll be using it in and what type of content you're playing to give me/us a better idea of what we're getting from that thing
PS I've been suggested getting the 10"/12" version if you're going to implement it in your home theater and have a medium+ sized room.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
I'd look around on the used market, personally.... $250 can get you a lot of sub.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
It won't be real soon. Tuition sucks! But eventually I'll make the upgrade and post my results. I've been meaning to write a short review on my Lsi9's... -
It won't be real soon. Tuition sucks! But eventually I'll make the upgrade and post my results. I've been meaning to write a short review on my Lsi9's...DARE TO SOAR:
Your attitude, almost always determine your altitude in life -
Check audiogon. There of plenty of subs in and around your price range. If you find one that's close you won't have to worry about shipping either. Definitely leave the car stuff in the car.
