cs 10 match rc 85 1
Will the cs 10 center match rc 85i 2 fronts and 2 rc 85i reares?
Post edited by the pro33 on
Yes, the CS10 is timbre matched to the RCi series in-walls.
I'd recommend going with the CS20 though myself. The RC85i's are the largest in-walls in the RCi series, and the CS10 might have a little bit of trouble keeping up with them.
The center channel carries over 50% of a movies soundtrack, so it's a pretty crucial speaker. You don't want to skimp out on it.
If you're not wanting to drop the coin on the CS20, try to snag a CS2. That's the older version of the CS20, and is essentially the same speaker, aside from a few slight differences...mainly the aesthetics.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
