Tube preamp ideas for SS amp.
MB,SC Polkie
I have several Adcom amps to play with, and have started to consider a tube pre. I'm using a Adcom 5500 now, and would love to hear your opinions for a good tube preamp. I do listen to vinyl and like to see a processor loop if poss. I can spend $500. for sure, and maybe even $1,000. Big difference I know, so maybe you can make two reccomendations. I hear if your going to mix tube and SS, the best config. is tube pre, and SS amp. Thanks!
BEING GOOD GETS YOU STUFF. BEING STUFF GETS YOU GOOD!....Mr. Bungle
Post edited by MB,SC Polkie on
VTL 2.5 pre is awesome.
Belles 21A w/auricaps,,,Dodd MLP,,,, for starters,, good luck.JC approves....he told me so. (F-1 nut)
Do you need a remote?
Mapletree Line 2A SE, Ultra 4A SE if you need a phono section."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
sucks2beme wrote: »Nobody NEEDS a remote.
I do. I'll never go back to pre w/out one. -
sucks2beme wrote: »Nobody NEEDS a remote. Or tone controls!
I don't need tone controls but do need the remote. -
Armchair audiophile.
Oh yeah thats me and loving every minute of it
I had to come back and edit this post. I am not a audiophile yet. At least I don't think so -
http://dictionary.reference.com/browse/audiophileau⋅di⋅o⋅phile
Show Spelled Pronunciation [aw-dee-uh-fahyl] Show IPA
Use audiophile in a Sentence
–noun
a person who is especially interested in high-fidelity sound reproduction."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Holy Dog Sheet I may be one some day!!
If you ever get up to Columbia you're welcome to bring your amps and try them out with my Carver C-19. It's an excellent sounding pre with SS amps and has a MM & MC phono section. No remote, but they are in your price range if you can find one.
The VTL TL 2.5 is very good and can be had with a remote.If you can do without a remote i would first recommend a used SAS Audiolabs 10A linestage or the Mapletree line 2A SE is supposed to be pretty sweet too.good luck....WCW IIIRogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers. -
Hagerman Clarinet tube pre-amp. You can build it for $600 with all premium capacitors. I use the Auricaps.
