Help with Carver TFM-25
nguyendot
nguyendot Posts: 3,594
edited December 2011 in Electronics
Just picked up a Carver TFM-25 and the left channel sounds very scratchy.
It's constant. Where should I begin?
thanks
Main Surround -
Post edited by nguyendot on
  • thsmith
    thsmith Posts: 6,082
    edited August 2009
    Most likely the power rail voltage needs to be adjusted or a transitor is hot or a cap is leaking or bulging.
    carveraudio.com forum or Rolland at Hi-Tech or Rita.
    treitz3 Posts: 19,999
    edited August 2009
    The amp needs to be serviced if you have ruled out all other components in your rig, including cables.
  • nguyendot
    edited August 2009
    The amp is the only thing new to the setup, I simply replaced the NAD 214 with the Carver.
    I already knew it needs service, that is why I asked where to begin, otherwise it'd be working.
    My main questions were what to look for in the amp itself, such as thsmith was pointing me to. I looked inside and there are no bulging caps, none leaking or burnt. It looks like the distortion is coming from the input stage. When you turn up the volume past 1/4 or even close, the amp goes into protect mode. If I pull the left channel connection from the input stage the to amp stage, the issue goes away - no protect mode. I swapped the right channel connection to the left amplifier and it plays clean. This leads me to believe there is a bad component or connection on the input stage PCB. Since this PCB is removable I believe it should be easily serviced. There aren't that many components on it and I believe in 4hr or less anyone handy with a soldering iron can replace all the components (i am not handy with one).
    Is there something I should look for on this pcb specifically?
    thanks
    Main Surround -
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited August 2009
    Some of the earlier TFM-25s were bad about the transistor solder connections. Hope this helps.
    Tony M Posts: 11,624
    edited August 2009
    Your pretty good with circuits tuan, I think your going to fix that thing.
  • nguyendot
    edited August 2009
    On the input stage PCB?
    If so I'll resolder them, there aren't many.
    Main Surround -
  • cwsmith68
    cwsmith68 Posts: 434
    Anyone in the club good with fixing Carver amps? TFM LINE?
    Main system:
    Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
  • gdb
    gdb Posts: 6,012
    There is only one place that I send Carver gear to: http://www.hitechaudioltd.com/ Talk to Rolland.:wink:
  • cwsmith68
    Cool. Thanks. I'll give em a call next week.
    Main system:
