DSW Micro PRO 1000
polkanddie
polkanddie Posts: 224
edited October 2009 in Speakers
Anyone else notice that they have this on newegg for $379 w/ free shipping????!!! Also does anyone have this, and what do you think of it??
TV- Insignia 46'' LED,1080p,120hz
Monster Power center hts3600 mk2
Onkyo tx sr 503
Rm6600 with 4 sanus stands
SUB(DIY)
Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
extras... RT10's.rti4s.atrium 5's.
"sticking feathers up your butt does not make you a chicken"-Tyler Durden
Post edited by polkanddie on
  • mmadden28
    mmadden28 Posts: 4,283
    edited July 2009
    polkanddie wrote: »
    Well that's better than the Refurb (although likely a new unit) plus shipping from PolkDirect on eBay. Well unless of course you win it at auction for less.
    ____________________
    Pool: Atrium 60's/45's
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    I was looking into that sub actually and noticed it dropped on newegg just a few days ago. Not a bad score at all considering refurbished its 349 on fleabay (polk ebay store). Unless someone chimes in and tells me what they can compare this sub to, I'd have to hear it first before I buy it.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2009
    It's a nice little sub, no SPL king but it blends very well for music. I've owned dual 4000's and a single 2000 and they're great. If you plan on using it for both HT and Music I'd look at the 3000 or 4000.
    P.S. To the member that bought my 4000 I want it back.:D
  • polkanddie
    edited August 2009
    And.......it just went back up to $899.... so sad
    Onkyo tx sr 503
    SUB(DIY)
    treitz3 Posts: 19,274
    edited August 2009
    xcapri79 wrote: »
    I have the Micropro 1000.......it is a nice compact sub.
    Huh?
  • kevon27
    kevon27 Posts: 18
    edited October 2009
    DSW microPRO 1000 is NICE... I got it yesterday from Newegg for $379. Clean power. Still testing and will try to push it to it's limits but the wife has to be out the house.
    One thing, who ever at Polk allowed these subs to go to market with it's ridiculous volume control system should be seriously flogged with a rubber hose. It's so stupid. They could have just used a small led display showing the volume numbers. Instead, you have to learn morse code to change the volume.
  • Polkitup2
    Polkitup2 Posts: 1,623
    edited October 2009
    I have one and agree that the blinking led light scheme is probably the most ridiculous control system I have ever encounter on an audio product. Not that you should really have to change it often once it's calibrated, but still, was an LED display that much more in cost? For example, volume level 29, slow blink, another slow blink, fast blink, fast blink, fast blink, fast blink, fast blink, fast blink, fast blink, fast blink, fast blink. Wait was that 8 or 9 fast blinks? Let's try again, slow blink, another slow blink, fast blink, fast blink, fast blink, fast blink, fast blink, fast blink, fast blink, fast blink, fast blink. Crazy.....But I like it now that it is set up.
  • mmadden28
    edited October 2009
    kevon27 wrote: »
    ...ridiculous volume control system.......It's so stupid. They could have just used a small led display showing the volume numbers. Instead, you have to learn morse code to change the volume.
    Polkitup2 wrote: »
    Amen!
    Definitely a FAIL. I actually had to RTFM to figure out how to figure out where the volume was set.
    I'm not a fan of digital volume controls to begin with, but at least some kind of readout like a level meter-even if just a series of LEDs. I like the old fashioned manual volume controls-and if remote volume is required then a motorized one.
    I'm using the volume control on my Velo SMS-1 sub EQ so it doesn't impact me now, but the initial setting of the volume on the sub was a PITA--even if I didn't need the SMS-1 to correct my room's sub-bass issues, I'd still use it just for the volume controls.
    Note: the Sub's own EQ did a pretty good job with the auto correction--I still needed to tweak a little more with the SMS-1, but close enough that if I didn't have an issue with the volume control, I probably wouldn't even have the SMS-1 in play.
    edited October 2009
    Hmmm, I guess your opinion of small and mine are two different things. It's about 16x16 not including space for the cord. Not what I would consider small.
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2009
    You must be thinking about a different sub; the micropro 1000 is 12 5/8 x 11 x 12 3/4.
    SOPA
    edited October 2009
    Crap. You are both right. I was thinking of the PSW1000. My bad, carry on.
    edited October 2009
    That's why I made the comment. That sub isn't what I would consider small.
    Anyhoo, back to your regularly scheduled program.....
  • restanim
    restanim Posts: 227
    edited October 2009
    It is back to the same low price :)
    Original Price: $899.99
    You Save: $520.00
    $379.99
    polkaudio
    Currently Own:
    RTA-11T Light Oak, Aug/2011 to present
    SDA-CRS+ Aug/2011 to present
    RTA-11T Black, Dec/2013 to present
    Previously Owned:
    SDA-SRS 2.3 May/1990 to June/1991
    SRS 1.2TL June/1991 to May/1995
    SDA-1C Aug/2005 to Dec/2011
    SRS 1.2TL Sept/2009 to Sept/2015
