PSW650 High Pass Filter Setting ?
In the manual that came with my PSW650 sub it says the high pass shouldn't need touching and that it should stay in the "0" postion. The swith on the back has a "Full Range" and "80" choice. Which of these is the "0" position ? I'm guessing it's the "Full Range" ?????
Onkyo TX-SR800 set up for 7.2
RTi150s Mains
RM7600 Surrounds & Center
PSW650 Sub & PSW202 Sub
Denon DVM1805 DVD
Toshiba 32 in. HDTV
RTi150s Mains
Denon DVM1805 DVD
Toshiba 32 in. HDTV
Post edited by chluffey on
I got my 650 when it first came out. Mine says "full range" and "80hz". I guess they changed the full range to a "0" on the later models.
You are correct with "0" being full range.
Maurice
