Good music on bluray recommendations
slowpolky
slowpolky Posts: 714
edited July 2009 in Music & Movies
I would like some pesonal recommendations for some good tunes to listen to on bluray . My system isnt quite ready to do justice for vynal records so in the meantime my ps3 is the best source I have right now . I lam open to pretty much all types of music and have blockbuster and netflix so I can try before I buy
Does bluray do a better job than sacd? I would think it should with all the extra data that can be stored
Please refrain yourself from posting negative feedback in the post
Thank you in advance for your valuble input fellow polkies
Post edited by slowpolky on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    Haven't heard/experienced any blu ray-only audio but if you're not going to give SACD's (well recorded ones) a chance I would have to say its a bit unfair. Plus you'll find a wide selection of them considering the format has been out for years, as far as blu ray goes I only get movies on BD. You should try it out!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2009
    Try this one, the more I watch and listen the more I want to...
    Dave Matthews & Tim Reynolds: Live at Radio City Music Hall [Blu-ray] (2007)
    http://www.amazon.com/Dave-Matthews-Tim-Reynolds-Blu-ray/dp/B000T4SWXO/ref=sr_1_2?ie=UTF8&s=dvd&qid=1248865100&sr=8-2
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ballen823
    ballen823 Posts: 110
    edited July 2009
    Try Nine Inch Nails - Beside You in Time.
    The DM & TR disc is a great disc, but the NIN will knock your socks off.
