need a little help with sda srs
lbristow
lbristow Posts: 131
edited August 2009 in Vintage Speakers
my wife's 2yr old nephew decided to push in the dust cover on one of my drivers, can I get this back out and will it effect sound quality at all:mad: Thanks for the help.
Post edited by lbristow on
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited July 2009
    Before I suggest what to do, you should have done a forum search because this has been discussed many times.
    Try a piece of tape like "Scotch" and gently adhear it to the dented dust cap. If it does not pull out the first time try applying more of the tapes surface to the cap. If this fails try using something like Duct Tape which had as higher adhesion level.
    Let us know how you make out.
  • me_myself_I
    me_myself_I Posts: 15
    edited July 2009
    lbristow wrote: »
    A hand vacuum is your friend when this happens.
  • NJPOLKER
    edited July 2009
    I would not use a vacuum.
    Toolfan66 Posts: 18,184
    edited July 2009
    Lasareath wrote: »
    No Vacuum. Sometimes Duct tape works, most of the time you are left with wrinkled dust covers.
    Did you beat the Child?
    Just pushed his nose in...:p
  • NJPOLKER
    edited July 2009
    Lasareath wrote: »
    Spoken like true Polk Heads
    nooshinjohn Posts: 26,000
    edited July 2009
    Were it my child, there would have been a burial in the cornfield behind the house. Maybe that explains why I don't have kids...
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    in most cases a "wrinkled / pushed in" the dust cover will not affect sound quality.
    also it may be possible to remove the damaged one and glue in a replacement.
    perhaps Polk Customer service would also provide a repair solution otherwise perhaps ...have the parents of the child reimburse you for a replacement driver.
    I think you were lucky ... just think a 2 year could do a lot worse damage.
    I did come across a suggestion to put on some really rocking music and turn up the volume as the sound pressure level will re-inflate the dust cover... no warranties
  • AudioGenics
    edited July 2009
    forgot to add...
    since it was the wife's relative...
    you could say that it is time for an upgrade to the speaker system
    since the speaker is damage and just doesn't sound the same...
    its an audiophile thing......
  • NJPOLKER
    edited July 2009
    This is one of the reasons I keep the grills on all the time.
    Imagine if the child got to the tweeters.
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2009
    lbristow wrote: »
    When working on mine. I dropped one from my hand and I caught it....and pushed the cover in completely,,,tape had no chance and I had little to lose. I put a 90 degree bend in a straight sewing pin and inserted it to the bend and pulled it out with needle nose pliers..:eek:
    Not the best treatment, but it worked perfectly!!:D
    Good luck!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • MB,SC Polkie
    MB,SC Polkie Posts: 30
    edited July 2009
    If you use the handheld part of your vaccum with the corner attachment on it won't suck so hard risking damage. The corner attachment I am reffering to has a small slit opening in the end rather than a large circular opening. Cover up most of the end with some tape or something. If it doesn't pull it out, simply retape allowing more of the slit open. Also gently massage the edge of the dustcap encouraging it to pop out while vaccuming it. I have used this with great results.
    Fabric covers generally look fine after. Paper or plastic ones sometimes have permanent creases after. It's just the nature of the beast. I wouldn't use a pin, as it will leave you with a hole unless you can just snag it. I haven't had much luck that way....no disrespect to the guy who suggested the pin method, but I just haven't found it to be as good of an outcome. GOODLUCK, and if they won't get you a new driver /dustcap etc, by all means push in the childs nose in front of his parents.:D
    BEING GOOD GETS YOU STUFF. BEING STUFF GETS YOU GOOD!....Mr. Bungle :D
    F1nut Posts: 51,998
    edited July 2009
    Tape.
  • lbristow
    lbristow Posts: 131
    edited July 2009
    thanks for all of the advice:D Needless to say I had to leave the room to not make an **** of myself. Yes, if it were my kid I would offer to buy a new driver or cover whatever cost the damage may be, if any. I will give these suggestions a try. The only problem I see is that it is not in the center, but center to edge. I guesst if all else fails I will get a replacement. Buy the way, just purchased a pair of RTi A9s for the basement, in cherry. Interested to see what these sound like compaired to the sda's. May have to get some chicken wire next time I am at Lowes:D
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2009
    :)No offense taken at all...it was a last resort for me, I couldn't get anything to work.
    But, what will a .025" pin do to hurt the sound of the driver?? The area in question seems to be a mesh of some type, see photo of mine attached.
    Again, it was a last resort that seems to have worked:confused:
    Click on photo to get a better view.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • MB,SC Polkie
    edited July 2009
    vmaxer wrote: »
    Ahh, yes. You are correct about it being more of a mesh style cap. This is a candidate for the pin method. A little snag with a pin may work. I pesonally just feel a little more comfortable using other methods. It seems most would rather use the tape theory. Again, I meant no disrespect. I simply was just trying to advise by my personal experiences. Have a good one.:)
  • NJPOLKER
    edited July 2009
    Tape is a good way to go but not the only option.
    If you have some Duct Tape and it will not pull out the dent on the first or second pull you should apply the tape again and leave it on the cap for a minute or longer. The extra time will allow the adhesive to bond a little better and increase your chance of success. I used a high bond open cell/foam pressure sensitive tape to pull one of mine and it worked like a champ. Too much bond and you will be buying a replacement driver.
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2009
    I agree with you completely. I tried tape before the pin. I guess I didn't have the correct type and I was a bit upset at myself for letting it happen... I figured I had nothing to lose and tried it and it worked. I figured if I was going to have to replace it, what the hell??
    I am not dis-agreeing in any way, but was wondering how such a small hole would hurt even if this was a paper type?? Trying to learn and understand...It's just my nature to want to understand the how's and why's...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • me_myself_I
    edited July 2009
    vmaxer wrote: »
    Vmaxer,
    The worst case situation with poking holes in the dust cap is that an air leak will be introduced if the speaker driver has what's called a "vented pole piece". If the driver in question has a solid dustcap, check to make sure there isn't a hole in the back of the driver magnet. A leak can cause problems with the driver loading and screw up the box alignment.
    The advantage to have a vented pole piece with respect to a dented dust cap is that one can often "push out" the dustcap by inserting a long object through the vent.
    If the driver has a mesh dustcap, it's almost a certainty that the pole-piece isn't vented, so using a pin or paper clip to pull it out should be ok. If done poorly, a hole can be a cosmetic problem for some people. And if the hole is big enough, particles can get into the voice-coil gap.
    I'm a proponent of using a vacuum to "suck out" the dust cap. If done carefully, there is no damage to the driver/dustcap and also no chance that adhesive residue from tape will stay on the dust cap.
  • NJPOLKER
    edited July 2009
    Almost all tears start small about the size of a lets say - **** or pin **** :p
    While I'm at it the only way you should use suction to pull it out is if a good woman does it.
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2009
    Vmaxer,
    Thanks for the information, makes sense!!;)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • NJPOLKER
    edited July 2009
    Me Myself and Irene, There is very little chance that the adhesive will transfer to the cap unless either left on the cap for a long period of time or heat is applied and that will not happen in this case, at least I'd hope not.
    Also if you have a piece of single coated foam tape used for sealing windows and such it can do a great job. High adhesion and will form to any creases in the cap for a better hold.
    I wish some one would tag this thread properly so others down the road can find this thread and not start another.
  • me_myself_I
    edited July 2009
    vmaxer wrote: »
    You're very welcome.
  • lbristow
    lbristow Posts: 131
    edited July 2009
    I have tried the vacuum and tape, no luck. I guess I will try the pin method and see what happens:eek:
  • me_myself_I
    edited July 2009
    lbristow wrote: »
    lbristow,
    Do you have a picture of the damage? Is there some special circumstance we're not aware of? Thanks.
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2009
    lbristow wrote: »
    Let us know how it works out...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • NJPOLKER
    edited July 2009
    Good idea pictures always help.
  • lbristow
    lbristow Posts: 131
    edited August 2009
    a vacuum with a little more power pulled it out. No damage to the driver:D Thanks for the help
  • me_myself_I
    edited August 2009
    lbristow wrote: »
    I'm glad the vacuum trick worked well for you. It's a handy trick to remember that also works on dome tweeters.
    I'm not sure why there is an aversion to it from a couple of people in this thread, but it works almost every time. The only time it didn't work for me was with one of those odd JBL metal dust caps. Luckily they make replacements for those. :p
    F1nut Posts: 51,998
    edited August 2009
    Pretty simple really, we found that the other methods worked best.
