Where can I get some of the gold terminal connectors?
Got some monitor 40's that are missing the gold terminal connectors
anybody know where I an buy some
Post edited by jojomgee on
Are you talking about the brass jumpers that connect upper and lower + -?
If so, you can polk cs ph. # @ top of the page. Or, you can just replace them with some wire?I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
44 dollars for 4 set and the copper thingy for HF LFI am 100% BORN DEAF and No I am not kidding!
Why am I here? My wife's hearing!
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA -
If your talking Binding posts, try here.
If your talking about the jumper between upper and lower binding posts, as obieone said, just use some speaker wire to jumper them. Nothing magical about the jumpers. As a matter of fact many will recommend replacing them with quality speaker wire anyway.
But if you really want jumpers, perhaps these or these (assuming the spade will fit)____________________
Pool: Atrium 60's/45's -
Yeah the jumpers....I have been using speaker wire but I'd like to have the brass jumpers.......OCD
Try customer service, otherwise "pretend" your speaker wire is actually the jumpers to ease your OCD, lol.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Do you use thes on your speakers? Do they make a differance to your ears? If so for as little as $10.00 a speaker I might try them.
Thanks potee -
That's a backwards move."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
So speaker wire works better?
Yes. Copper is a better conductor than brass."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks potee
I don't. Can't say I ever really did any comparisons--too busy and too many recommend it as a cheap tweak and for cLose to no additional cost? No Brainer.
Jojo, if you really want the jumpers instead of speaker wires, the Cardas jumpers I linked to are solid Copper.____________________
