1.2TL binding post nut size
awe-d-o-file
awe-d-o-file Posts: 146
edited July 2009 in Vintage Speakers
I took a red and black plastic stock binding post nut to my local hardware store that has a great stock and found they threaded onto a 5/16" fine thread perfectly. I then bought 8 nuts to replace the plastic ones since they don't tighten down to well and are prone to strip. I hoped they would have knurled circular ones but no, only hex nuts. Anyway I got home and they don't fit. They go a rotation or two and stop. I guess I will try 5/16" coarse thread. Anyone know the actual size?
ET
ET
System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant!
Post edited by awe-d-o-file on
  • george daniel
    george daniel Posts: 12,096
    edited July 2009
    don't know/remenber the size,(i'm guessing coarse thread), have you consideres replacing them at some point? -
  • gdb
    gdb Posts: 6,012
    edited July 2009
    You could try wingnuts since they dont carry knurled ones. BTW, 5/16 is the wrench size not the post/screw size. That would be HUGE !;)
    F1nut Posts: 51,997
    edited July 2009
    There are many excellent aftermaket binding posts that are all much better choices than nuts from the hardware store.
    Tony M Posts: 11,727
    edited July 2009
    I went through this problem myself a couple of months ago. I could not find it at Lowes Home imp. and so I went to a nut and bolt/ fastener store. The expert said metric something or other and I bought some but had your same problem too.
    I looked at threads here and bought 4 new posts from parts express( limited budget mindset sometimes)and they were very easy to replace!!!
  • fbm211
    fbm211 Posts: 1,488
    edited July 2009
    Lasareath wrote: »
    These are the ones I will buy very soon to do mine over, the short ones.
    http://www.soniccraft.com/products/connections/bindingpost/cardas_ccgr.htm
    Get em while there 20% off sal.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • awe-d-o-file
    edited July 2009
    I will buy some nice WBT's which I can get at cost. In the mean time I want to just put better nuts than the stock plastic to better hold the wire in place. Can you help on that F1? Do you know the size? That's what the thread is about.
    ET
    ET
  • awe-d-o-file
    edited July 2009
    Yes when I re-do my x-overs I wil replace them. Not ready for that big a project time or financially. I have been getting parts here and there. I have foil inductirs for the HF side and Mills resistors. Need caps and posts to complete that.
    ET
  • Face
    Face Posts: 14,340
    edited July 2009
    I hope the inductors have similar DCR's to the OEM components.
    F1nut Posts: 51,997
    edited July 2009
    May I suggest you put spades on your wire as the stock posts should have no problem with them. I'm sorry, but I do not know the thread size.
    F1nut Posts: 51,997
    edited July 2009
    Ok, I managed to find an original Polk binding post around here. The thread is 8mm x 1.00.
  • awe-d-o-file
    edited July 2009
    Face wrote: »
    they do, thanks
    ET
  • awe-d-o-file
    edited July 2009
    I do use spades and I am going back to the hardware store today to try that size. Much appreciated!
    ET
  • awe-d-o-file
    edited July 2009
    Went to the store and that size did it. Much appreciated.
    ET
    F1nut Posts: 51,997
    edited July 2009
    Cool, glad to help. Unlike the BOZO twins, I know WTF I'm talking about.
