Refurbishing a Monitor 7A
jimbo1421
jimbo1421 Posts: 772
edited March 2011 in Vintage Speakers
Hello all.
Before I tackle rebuilding my SDA-1B crossovers I thought I would refurbish some easier speakers. I have a pair of Monitor 7As and two pairs of Monitor 10s. That ought to give me plenty of practice, polishing my soldering skills and learning the names of the parts. (I wouldn't know a cap from a cap in my ****!)
First up - Monitor 7A. These sounded quite good before I took them apart. I think I might use them for surrounds with the SDAs or in a bedroom or office system.
Before I start, I have some questions, the answers to which will determine how much I spend on the crossovers. I attached some pics of the drivers. Are the tweeters the American Peerless? There are no markings on them except for a number stamp; one is 55142778, the other is almost illegible. Are they replaceable? I ask because while I was desoldering a big lump of solder and wire from one of the terminals a puff of smoke emerged from the face side. I hooked it up and played it again; it sounded about as before, kinda scratchy, but functioning. Both tweeters sounded scratchy when hooked up individually, something I didn't notice when they were all in the cabinet.
Secondly, one tweeter has a white powdery substance on the inside which brushes off. Any ideas about what it is or if it signifies some damage or corrosion?
Thank you for your attention.
Regards,
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
Post edited by jimbo1421 on
  • jimbo1421
    edited July 2009
    Hello again,
    I have attached a photo of one of the MW6500s. Does the label look a bit odd. It looks to me as if some kind of fluid has leaked under the label. Notice the light spots near the center where the label is not completely stuck. Is there fluid inside the driver that can leak? Or is the mottled appearance from the label adhesive, dark where the label is stuck down tight, light where it isn't?
    Regards,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • lixuelai
    lixuelai Posts: 6
    edited July 2009
    Those look like Peerless with the hole in the middle and the metal plate. Not sure I would have experimented on a Monitor 7 with Peerless. :eek:
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    found these comments about "white powdery"....
    calcium silicate type material or...
    Old steel chassis boxes are frequently zinc plated.
    When the plating gets damp, it oxidizes.
    you get a white powder that is zinc oxide.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited July 2009
    Hello. Just curious are you using a soldering "iron" or "gun?"
    I am by no means an expert, but I read somewhere that a 'gun' is very high wattage, which can damage electrical components. Maybe what happened to your tweeter?
    I really have no idea, but hope this might be of some use.
    Those are the peerless tweeters. I have a pair of 7Bs I just got off craigslist. One of the tweeters also has that "raspy" sound with certain recordings... It sounds very similar to the other one why playing music, etc.... but when I use the test tone, it becomes very distinct.
    Sorry for the minor hijack, I'm just also trying to figure out what happened to my tweeter too.
  • jimbo1421
    edited July 2009
    lixuelai wrote: »
    Did that puff of smoke that I mentioned have anything to do with your judgement?:o
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited July 2009
    Hi John,
    I used a 45 watt desoldering iron but the lump of solder and old wire was so big that I had to hold the iron on it for a while, too long, I guess. Someone else had been inside the box before me. The leads to the tweeters had been resoldered without removing the old solder and broken off wire. Also, one MW6500 looks like a replacement; the basket is bright steel, not painted black and there is no date on it.
    The tweeters didn't sound raspy in the box, just when I hooked them up separately to my receiver with alligator clips. The one that emitted the puff of smoke during desoldering didn't sound any worse after the smoke incident. Perhaps it was just some paint that vaporized, although I see no sign of that.
    Are these the American or Danish Peerless tweeters?
    Regards,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • JohnLocke88
    edited July 2009
    Someone told me the American's are the ones with the holes, and the Danish are the solid ones. Could have that completely wrong though, I'll check my 7B thread and update.
  • skrol
    skrol Posts: 3,455
    edited July 2009
    My USA Peerless have a dimple.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jimbo1421
    edited July 2009
    skrol wrote: »
    Thanks, guys. They are American then. If they need replacing, either due to age or mishap, are any available?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    You know I was going to add, you should seal'em up when you puttem back in an enclosure with caulk cord around the edge of the driver basket. Proved to be a much better seal on my sda's and loved the tight bass I got, also utilized high density foam tape (or you can use dynamat) on the basket themselves. Not sure if its an approach youd take on a smaller speaker but it doesnt hurt to try?
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • jimbo1421
    edited July 2009
    kawizx9r wrote: »
    I sure will, kawizx9r. I have a bunch of rope caulk and Dynamat Extreme left over from my Monitor 10s. Today I reglued the back of one of the boxes. It had pulled loose out of the rabbet by about 1/8".
    Next I will be shopping for replacement capacitors and resistors for the crossovers. Any suggestions for suppliers in the medium price range?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • skrol
    skrol Posts: 3,455
    edited July 2009
    Mine also had a Made in USA sticker. See posts #18 and #20 in the following thread:
    http://www.polkaudio.com/forums/showthread.php?t=83521&highlight=Monitor
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jimbo1421
    edited July 2009
    No Made in USA sticker on mine. No dimple on the shiny plate behind the magnet, either. They do have the hole in the silk dome.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • skrol
    skrol Posts: 3,455
    edited July 2009
    For the dimple I was referring to the dome. Some have a hole in the center some have a dimple. Your backs do look a bit different than mine. Do you know what year yours were mfg'd? Mine were 1983.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jimbo1421
    edited July 2009
    1979 according to the only date stamp, which is on one of the MW6500s.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited July 2009
    Hello again.
    I have attached a crossover picture. I cribbed the replacement capacitors from ben62670, the resistors I am not sure about.
    The big yellow cap has printed on it:
    T.I. 12uF J
    100VDC
    Mexico
    Replacement: Dayton DMPC-12 12uF 250V Polypropylene
    http://www.parts-express.com/pe/pshowdetl.cfm?PartNumber=027-430
    The smaller black capacitor reads
    TSI-7818
    PXC34LP50
    34uF-50VAC
    AC
    Replacement: Jantzen 33uF 400V Crosscap
    http://www.parts-express.com/pe/pshowdetl.cfm?PartNumber=027-944&DID=7
    Is the 33uF an OK replacement for the 34uF?
    One resistor reads
    7745 TRW PW5
    4.7Ω 10%
    and I found a Dayton DNR-4.7 4.7 Ohm 10W Precision Audio Grade Resistor
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=004-4.7
    The other resistor reads
    7745 TRW PW5
    and I found Dayton DNR-2.7 2.7 Ohm 10W Precision Audio Grade Resistor
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=004-2.7
    I also looked at the Mills resistor selection page (http://www.parts-express.com/mills-crossover-resistors.cfm) but did not see the precise values of mine. I have seen Mills recommended on other threads but I don't know if 2.5Ω and 4.5Ω is close enough.
    Are these the right choices? Could they be improved upon for a $20 uptick in the price?
    Regards,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • schwarcw
    schwarcw Posts: 7,358
    edited July 2009
    Greetings Jimbo!
    Those replacements will work just fine. You may want to try a better cap in the tweeter circuit. A 12 uF Sonicap Gen 11 from Soniccraft is what I would use. I think it's worth the extra money. The exact resistor values are recommended. Good luck!
    Carl
  • jimbo1421
    edited July 2009
    Thanks for the confirmation, Carl. I think the Sonicaps run about $20 apiece, right? I know they are well regarded here, but for a first time effort and the chance of **** up (see post #1) I think I will stick with the Daytons. This is a training exercise for me and I can always change them out later.
    Regards,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited July 2009
    I ordered the caps & resistors today and also Dynamatted the PRs and MW6500s. While waiting for the parts I am looking ahead to final assembly. The speaker wires were soldered to the speaker terminals and I am thinking of using spade terminals. Can anyone comment on the relative merits of the two connection methods?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited August 2009
    Hello again,
    The new capacitors and resistors arrived today. Does anyone have any tips for desoldering & removing the old parts without burning anything? Should I try to remove as much of the old solder as possible or leave it to reuse? Some of the puddles of solder are as much as 1/2" across. It would seem too easy to have it run across the gaps in the printed circuit.
    Thanks,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • madmike
    madmike Posts: 81
    edited August 2009
    Use Solder wick to remove the majority of the solder then you end up with a cleaner solder joint. There is a video on how to do this here http://www.ehow.com/video_4435740_use-solder-wick-remove-solder.html
  • jimbo1421
    edited August 2009
    Thanks for the link, MM. I watched the whole series. Do you prefer the wick to a desoldering iron with the suction bulb?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2009
    jimbo1421 wrote: »
    Jim
    I prefer solder suckers or bulbs.
  • jimbo1421
    edited August 2009
    Since a bulb desoldering iron is what I have, that is what I am using.
    There does not appear that there is any in/out or +/- direction on either the caps or resistors. I assume that it does not matter which way they are soldered in, right?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited August 2009
    Does it matter if the resistors are tight against each other? Will they overheat? I am running out of room on the board and the new parts are much bigger than the old.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • DaveOrAstroDave
    DaveOrAstroDave Posts: 20
    edited August 2009
    Hello there,
    Wow, it looks like you're doing exactly what I just did, right down to the parts selection! The only difference is I had to buy a new inductor too. Since you're using 10w resistors, I wouldn't worry so much about heat.. they're made to handle twice the power, so they shouldn't heat up as much to begin with, plus the added surface area means they'll dissipate heat faster.
    Also, yes, you are correct about the capacitors and resistors not having a polarity that you have to respect. Either way should work fine.
    I didn't think to dynamat my pair of 7A's, but I did use Moretite caulking cord to seal the drivers to the cabinets, as recommended in a few other threads. You might want to give it a try =)
    As for future upgrades, I was thinking of splitting the crossover network and add a second pair of terminals so the speakers can be bi-wired, but I'm skeptical about what kind of difference it would make...
    Anyway, good luck with the refurbishing project! As for me, I've still got one more speaker to go.
  • nikolas812
    nikolas812 Posts: 2,915
    edited August 2009
    jimbo1421 wrote: »
    Jim
    jimbo1421 wrote: »
    Jim
    1. Right. There non directional. Doesn't matter which way there oriented. Some caps do but there usually labeled +/- if so..
    2. I don't see why not. I think you would be fine. I think most people like to use Hot glue to hold everything together so nothing vibrates. I sometimes like to use a good double sided tape in some applications..
    Nik
    Nik
  • skrol
    skrol Posts: 3,455
    edited August 2009
    You can actually use Moretite for vibration reduction on the PR and MW baskets. It dampens out ringing very well. I don't know how well it will stay in place over a long duration though.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • nikolas812
    edited August 2009
    Huh. I never thought of this.. Bi-wiring may not make the biggest difference. But you would have the ability to Bi-amp and that opens up all kinds of things. Just one that comes to mind is a Tube amp on the highs and a SS amp on the Lows..
    Nik
  • jimbo1421
    edited August 2009
    Hey Nik & Dave,
    Thanks for your comments. Since it is difficult to get the components to sit as tightly on the board as the smaller originals I'll get a hot glue gun tomorrow and stick them down that way.
    I am still thinking of adding spade terminals to the speaker connections rather than resoldering them. When I desoldered the tweeter connections the caulk or glue that holds the leads in to the groove on the face bubbled, so I am reluctant to solder them back. Is there any reason not to use spade terminals?
    Thanks again,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
