Cheap tweak on my SDA 1C's
kawizx9r
kawizx9r Posts: 5,150
edited July 2009 in DIY, Mods & Tweaks
Ok well what I'm doing is not in anyway new to the audio world, nor is it regarding SDA's. I've seen the threads on conradicles new "black beauties" (props to ya theyre beautiful!) along with Darqueknights (you're definitely a man of wisdom and I enjoy your reading your posts) so I decided to take it upon myself to work on my SDA's I've just acquired about what....3 weeks ago? Currently applying MD's high density foam tape to the basket of my drivers, yes it's the cheap mans version since I'm on a tight budget, that I picked up at Home Depot. Also got some mortite caulking cord from there, and will be applying it in place of the stock seals. I'll be posting some pics up later, but right now I'm going to apply the mod to my left speaker only and as soon as tomorrow comes I will begin the comparison. This should be fun!
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104
heiney9 wrote: »
Any clue how to use the internet? Found it in about 10 sec.
Post edited by kawizx9r on
  • kawizx9r
    edited July 2009
    3 more drivers to go, jeez no moral support come on lol. I do like the fact that the caulk is very flexible and proves to provide a very tight seal between driver and cabinet. Cant wait to hear what they sound like
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Conradicles
    Conradicles Posts: 6,419
    edited July 2009
    Search Vibrapod...seems like another cheap tweak but I have no clue if it will actually work.
    Enjoy those SDA's and tubes!
  • Fongolio
    Fongolio Posts: 3,516
    edited July 2009
    Good luck and am interested in hearing about the results.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • kawizx9r
    edited July 2009
    Well, heres a pic of the mid driver and thought I'd add one of the "intimidating" crossover lol. The drivers were a B**** to pull out, these speakers really were virgins because the seals were so dam tight. I kind of laughed to myself though after pulling out the bass radiator, I remember reading on another forum about someone complaining that their speaker was the victim of a cruel joke or defect (he had a cs150) and didnt know that one of the bass drivers was actually a passive radiator when he opened it up to check it out.
    Wanted to add, looking at the internal wiring I'm half tempted to just rewire everything with some thicker and better quality speaker wire....am I thinking too much already?
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    edited July 2009
    Time to hear the output now am I right. Well I immediately noticed a "lack" of bass soon as I dialed in at around 1 o'clock on the volume, not necessarily a lack of but it sounded less boomy. I decided to switch it up between different styles of music such as Metallica, Tool, Bon Jovi, Styx, Sade that I generally listen to. As I turned the music up all I said was wow, where there is a shortness of bass at very low volumes, makes up for it at much higher volumes. The bass came in harder, quicker, and much more accurate as I A/B'd the stock speaker with the modded speaker. I had some intentions of utilizing these as part of my HT, but now I think I want to dedicate them primarily for music and with a simple mod using caulk and tape it's really made them even more music-friendly. I even threw on some rap and when it comes to bass-heavy music the differences are night and day. If you're considering doing this mod for your SDA's or any sealed enclosure for that matter, and listen to your music at moderate levels then by all means I recommend this mod as it is very budget friendly. If you're worried you might not like the mod, or listen to music at much lower volumes I wouldn't be worried since this stuff is really easy to take off and can be set back to stock condition. As for now I've got another enclosure to tape and seal up :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • george daniel
    george daniel Posts: 12,096
    edited July 2009
    Nice writeup,,, you seem very excited, as well you should be,, it's only gonna' get better,, now from looking at your pic's,,I have one question,,, Whatcha' gonna' do to those crossovers? That is where the fun really begins. Looks like you are on your way,,good luck,have fun,and most of all,,enjoy.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited July 2009
    +1 ^^^^^^
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2009
    I spent most of the day yesterday doing my SDS SRS 1.2tl's.. I used Dynamat Xtreme and Mortite. I played them a couple hours and them installed a set of Ben's silver IC's I bought used here on the forum...
    I am very happy with all of the changes!!! You wouldn't think there would be a noticable difference with the Dynamat and Mortite, but there is!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • kawizx9r
    edited July 2009
    I'm just glad with the results. On a further note, I also applied caulk cord to the rear speaker terminal, so if you do the same go for it just keep in mind the plastic is rather flimsy so careful not to overtighten your screws. As far as this mod goes, I kind of think of it as having better control of your drivers. With a bigger air leak, the drivers return to their normal position much quicker and could cause extreme movement of the drivers (at higher volumes) that in the end result to audible distortion. Definitely a must-do for those seeking something a bit more natural, but if you like that slightly more boomy, artificial bass then by all means leave them stock or go buy a blose.....LOL J/k about the bose we all know those should be sold at walmart anyway!
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    edited July 2009
    Doing the last driver now on the 2nd speaker along with the speaker terminals next....I just realized my tweeters/stereo drivers just turned 21 5 days ago. Stamped July 21 1988, except the dimensional drivers which are stamped August 21 1988, just thought Id share!
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    edited July 2009
    Very interesting, something I might have to take up once I move to a bigger place and have the work tools available. If I do perform it in the later future, do expect pictures+review and steps I took to achieve this.
    And thanks, love my moscode...youre running SS right? Should get your ears on some tubes!
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2009
    I use these on my turntable and the difference is amazing:cool:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • kawizx9r
    edited July 2009
    Well the above statements stand, and just wanted to add that imaging sounds a bit better to my ear (I guess it was being overwhelmed a tad bit by the boominess that was once present) and it sounds as if I were running a more powerful amp in regards to bass frequencies. Next mod out with the SL2k's, in with the RD0's :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
