Power Amps suggestion needed
I'm about buying a power amp around 200w+/c and not exceed $600
which model you suggest for?
Post edited by bbq on
you gave too little info as to how many channels you want, what speakers you are going to pair with, etc...
the following link has a very good deal on the adcom though.
http://www.polkaudio.com/forums/showthread.php?t=85743
buy from lee with confidence.Onkyo 805, RtiA5s, Csi5, Rti6s -
Hes pairing it with some sda 1a's he just acquired. bbq, keep in mind not all amps sound the same so I suggest doing plenty of research and get some feedback on possible amps you might purchase, alot of members here have extensive knowledge and experience with many amps. I myself run a moscode tube amp and I love every bit of sound I get from my 1c's, others will chime in as well though whether youre looking for a solid state amp or a tube amp.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
My brother needs an amp with 2ch is good enough. he has a pair of JBL L5 over 10 years old. one of the sub speakers was slightly bad with clicking sound when it loud, especially high bass. i wonder if JBL still carry the part for it, probably not.
How the GFA-555II compares to Carver or Parasound in general? he just gave the Parasound HCA-1500A for someone, so he needs something for replacement. I like this one but damn too expensive -
Adcom 565 mono blocks. 300 wpc. You can get them on the cheap on ebay or the gon. The only thing to know is you will have to strap the speaker grounds and chasis together to make it common ground.
Location? There's a nice Hafler XL600 in Indianapolis for $450 i believe. It'll have more power than you should ever need.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
would you be interested in a Rotel RB-990BX 200 watts per channel at 8 ohms.
thanks. -
Carver and Adcom are very good choices for your speakers. I would suggest a 2 Carver TFM 25's biamped. You should have little trouble staying within you budget.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
thuffman03 wrote: »Carver and Adcom are very good choices for your speakers. I would suggest a 2 Carver TFM 25's biamped. You should have little trouble staying within you budget.
I couldn't agree more than what Mr.thuffman03 is suggesting and its a setup that I use myself bbq.
Take Care bbq,
B.B.3Sony 52in.XBR6
Sony 32in.XBR6
Anthem AVM50V
Anthem PRE-2L
Sonic Frontiers SFCD-1
Carver C-9
Carver C-19 PreAmp
Carver C-16 PreAmp
2-Carver Silver 7-T's
4-Carver TFM55's
2-Carver TFM35's
1-Carver TFM25
Carver 490T
Denon DCD1560
Sony BDP-S350
Sony PS3
Nintendo Wii
Panasonic DMK23DVR
Speakers :
PolkAudio SDA-SRS
PolkAudio SDA-SRS 1.2TL
PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
PolkAudio RTA-15TL
PolkAudio M3
3-Velodyne F-1500's -
hey BB3.. do you want to sell your TFM35?. I have A500X which is the same specs as TFM35 and i love it. i don't know which one is better
I'll ask my brother if he wants Rotel RB-990BX or Hafler XL600
How much is Rotel RB-990BX? -
Sorry bbq, but I need it for bi-amping my back surrounds. I'll be using my 2 TFM35's for that purpose.
I'm sorry that I can't help you with this bbq, but you could check out amongst other places www.vintagehifipgh.com
Take Care, bbq
B.B.3Sony 52in.XBR6
Sony 32in.XBR6
Anthem AVM50V
Anthem PRE-2L
Carver C-9
Carver C-19 PreAmp
Carver C-16 PreAmp
4-Carver TFM55's
2-Carver TFM35's
1-Carver TFM25
Carver 490T
Denon DCD1560
Sony BDP-S350
Sony PS3
Nintendo Wii
Panasonic DMK23DVR
Speakers :
PolkAudio SDA-SRS
PolkAudio RTA-15TL
PolkAudio M3
I would recommend a TFM-35 / 45 /or a 55. Great bang for the buck. You can prob. pick up a pair of 35's for 600.00 and run them in mono or biamped.
