Stupid question
Nacken23
Nacken23 Posts: 100
edited July 2009 in Electronics
Hi all here's my stupid question
I have a pair of lsi15 4 ohm speakers and five 6 ohm speakers which will be powered by an onkyo 876 I will use the pre outs to power the lsi15 with a rotel 1572.
My question is what do I set the receiver to 4 ohm or 6 ohms do you even get to choose or is of all done automatic
Post edited by Nacken23 on
  • concealer404
    concealer404 Posts: 7,440
    edited July 2009
    Assuming that your Onkyo will handle the 6ohm load, you don't have to do anything.
    You never have to change anything to set a reciever/amp to put out a different ohm rating.
    Anyways, if you think about it, since you won't be powering the LSis with the reciever anyways, you only need to worry about the 6ohm. :)
  • Nacken23
    Nacken23 Posts: 100
    edited July 2009
    Thanks 4 ur quick reply
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited July 2009
    The 876, like most Onkyo receivers only have two options for speaker impedance. One option is "4 ohms" and that should only be used for speakers that have an impedance of 4 ohms but less than 6 ohms. The other option is "6 ohms" that should be used for speakers with an impedance between 6 and 16 ohms. It is on page 61 of your owners manual if you want to check it out and verify. So yours should be set to "6 ohms"
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
