Ben's Silver Innerconnects VS. Audioquest Diamaondbacks
Dawgfish
Dawgfish Posts: 2,554
edited July 2009 in 2 Channel Audio
Hello to all,
I have a question to any member(s) who has had a chance to here both of these cables. I am looking to purchase either one of these cables and was wondering which one y'all thought would be the better cable for my use?
FYI I will be using this between a Denon DCM-390 cd player and a Parasound P/FET-900II Preamp. My amp is an Adcom GFA-555 and speakers are RTA-12Bs. I am running mostly AQ Diamondback ICs in my system now and do enjoy the way they sound. However, I've read lots of great things about Ben's ICs and if they are vastly superior to the AQ's, I wouldn't mind trying them. If I had the cash to buy both and compare right now, I would, but money is tight, Thanks in advance
Post edited by Dawgfish on
  • concealer404
    concealer404 Posts: 7,440
    edited July 2009
    I'm not sure that either would be "superior." Different, for sure. Ben's will probably be more detailed, slightly brighter, being silver. In my system? That would be a bad thing.
    Yours? I have no idea. :) I say you try them. Would be easy to recoup most if not all of your money in the event you don't like them.
  • Ender
    Ender Posts: 603
    edited July 2009
    It's just as concealer says. I have Ben's IC's all over my system and for an SDA IC. Pretty awesome stuff he makes.
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • I-SIG
    I-SIG Posts: 2,243
    edited July 2009
    Not sure about Ben's IC's (I have his speaker cable) but the other silver cables in my system are a noticeable improvement over the AQ Diamondbacks. Don't be worried about them being bright. I used to think that. They are more detailed, top to bottom, but definitely not bright. If anything they are blacker in the background.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
