Which rti a towers should I get??
Mark1
Mark1 Posts: 41
edited December 2009 in Speakers
Hey guys, Just got my Csi a6!! Got the fxi a6's about a month ago. The setup is sounding better by the month.
I'm trying to figure out which Tower speakers are best for my front channels. From what I've read the A5's Have 2 midrange drivers and i've heard the A7's are lacking in the midrange because of the single midrange driver. The A9's need a lot of power to sound good and cost considerably more $$.
I've also read that it's best to set all speakers to small on the reciever so I don't even know why a 3way speaker is needed if you would be wanting to cut the low frequencies.
So what have some of you guys decided on and what do you suggest?
Post edited by Mark1 on
    Toolfan66 Posts: 18,063
    edited July 2009
    A9's are not that hard to run, a good receiver will power them just fine.
    If your setup is more HT then i say get the A5's
    If you want music and HT then i say A9's
  • mystik610
    mystik610 Posts: 699
    edited July 2009
    I would skip the A7 because of the lacking mid-bass driver. Whether or not you'll benefit from the extra woofers in the A9 depends on how you run your set-up.
    Is your system going to be used more heavily for music or home theater? Do you plan on getting a separate sub?
    A pair of RTi A5's will run you around 900 bucks...a pair of RTi A9's will run you about 1,700...given the price difference, if your primary usage is home theater, you'd be MUCH better getting the A5's, and spending the additional 800 on a high quality sub from HSU or SVS. On paper the RTi A9's will dip down to 18hz, but not with nearly as much authority as a high quality dedicated sub.
    Also...running a dedicated sub with the A9's can actually be detrimental, as you could run into issues with bass cancellation. Even with a bi-amped configuration, you'd be better off setting your front speakers to small, setting the crossovers around 80hz, and diverting all of your power to the high's and mid-range. This will give you more dynamic range in your front sound stage, while allowing a dedicated sub to handle the lower frequencies.
    The A9's would be better suited for music....but the superb sound quality of HSU subs sound great with music too. If you're using your system for music, however, the LSi series would be better suited for you than anything in the RTi line.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • mmadden28
    mmadden28 Posts: 4,283
    edited July 2009
    Setting the speakers to Large will run them Full Range. If you have a sub you may run into bass cancellation. If you set them to small you can set the high pass to the speakers and the low pass to the sub. If you don't have a sub, then run them large. If you do, run them small and crossover at 80Hz. You can adjust the crossover point to what sounds best. The lower drivers are still used, just not as much.
    I found my RTi12's (pretty much the same a the RTiA9's), had a pretty good low end. So much so that I almost forgot I didn't have a sub at one point. But adding a sub changed the whole dynamic.
    I certainly noticed a difference running the 12's on an AVR vs. running with a separate amp. They certainly benefit from more power if you want the full potential.
    I know it feels like a waste not really using all the drivers to their full potential when running them small. Personally, even if the final output were the same, I like the bigger speakers--they look nicer (in my room next to my large entertainment center)--they are a piece of furniture after all. I'm not sure where they sell the RTiA's, but if you have a chance to do a side by side comparison between the 5 and 9, that would be the way to go.
    What main speakers do you have now? Do you have a sub?
    ____________________
    Pool: Atrium 60's/45's
  • bklynNupe
    bklynNupe Posts: 728
    edited July 2009
    I've owned the a5's and they are great. Nice detail and very impressive. They are perfect for a smaller room and they really complemented by a nice sub.
    The a9's pack a lot of midrange punch! Many folks feel a sub is not need with the a9's. Perfect match for the a6.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
  • SivaNevets
    SivaNevets Posts: 303
    edited July 2009
    this is a classic question for the RTIa lines. Im running into the same problem. Seem to me more people prefer A5 + Sub> A7+ Sub that certainly sounds like a waste of sub-driver for me -> if u set cross over at 80hz and speakers to small, what are they designed for? what frequencies does the sub bass driver handle ont he A7s and A9s?
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
  • SolidSqual
    SolidSqual Posts: 5,218
    edited July 2009
    As return-customer of this hobby, I've heard the discussions over and over again regarding the RTi series. In my time, it was the RTi8 vs RTi10. What do you want more bass or midrange. I went with midrange and bought the Rti8 thinking I would just get a sub later. I like music, and that interest only increased with good speakers. Everyone told me to get the 8s for music. Thinking the 8s would provide a better midrange, I purchased them. Later, I yearned for more bass. So I bought an SVS PB10 sub, but I could never get it to integrate perfectly with the drivers. I heard the Rti10s sometime after I purchased my 8s and wished I had gone with the 10s. I detected no major mid-range weakness and really like the extra bass in two channel without a sub. In fact, because the bass drivers and mid drivers were obviously voiced together, I enjoyed a much greater coherency in the music that was difficult to find with the sub and Rti8 setup. If you like more music go with the bigger towers. If you like music as much as movies, go with the bigger towers. If you like mostly movies and will definitely buy a sub, then get the RTia5 and invest the extra cash into a high quality sub with the ability to disappear into your system (as much as possible).
    Mike
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2009
    Mark1
    Where are you located? It may be some polkies that live near you that wouldn't mind you coming by and taking a listen.
  • danz1906
    danz1906 Posts: 5,144
    edited July 2009
    Go for the A5s!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • jimmydep
    jimmydep Posts: 1,305
    edited July 2009
    SolidSqual wrote: »
    Mike
    I have to agree with Mike here, while I'm using the LSI series I've found for "music" that setting the speaker to large and letting a full range speaker do the job it was designed for sounds better than trying to integrate a sub.
    I listen to my music in the Pure Direct mode so the sub is disabled anyway, and I find the sound to be much better without the sub, more natural and much smoother sounding.
    I have heard both the A-5 and A-9's I'd have to say the A-9's would be a better choice. While the A-5 are very detailed in the mid and highs, they are seriously lacking in the low range, with the A-9 you get the FULL package, detailed mid and highs with a punch.
    With the A-9's I'd set the speakers to LARGE, if you don't like it you can always try other settings....
    Jimmy
  • mdk5068
    mdk5068 Posts: 204
    edited July 2009
    Hesitantly, as I see I am amongst a large group of non-believers, I would recommend the A7's. I understand the 2 mid ranged drivers of the a5's, as well as the obvious pull for the larger daddy a9. In the beginning, I really did just go with that rationale, but then I talked to a guy at polk who basically spent his life around the rti a series. He told that essentially the a7's were significantly more detailed than the a5's, even with a sub. He urged me that there was a reason the a7's sold out more frequently than either the a5's or the a9's, and that made sense to me. They are the obvious two ends of the spectrum, and they did create the a7 for a reason. Wanting to hear it before I just went ahead and bought, I went to the ny j&r to have a listen, and found that I did like the a7 the best. As everyone always says, everyone's ears are different. Mine told me that the larger cabinet would give me more sound than the a5, while not wasting the potential of the a9. The a9 to me seemed just huge. 500 watts of power, two handfuls of drivers, over 4 feet high...its just a monster. In the end you get what you pay for, but I nabbed the a7's I can say I don't regret it, even after hearing the a5's and a9's consistently.
    Bulls make money.
    Bears make money.
    Pigs get slaughtered.
    You, my friend, are the bacon.
  • bklynNupe
    edited July 2009
    SolidSqual wrote: »
    Mike
    +1, Mike I you pretty much nailed my experience and conclusions entirely just swap in the a5's and a9's.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
  • Mark1
    Mark1 Posts: 41
    edited July 2009
    I live by Des Moines, Iowa.
    I do like listening to music as much as I watch movies. I currently have a 100 watt yamaha sub that I'm using at the moment and probably will only be using it for another 2 months before I buy a newer one.
    It seems like on my csi a6 the 2 drivers have different cross over frequencies. Like one is mid range and the other more bass. Is that similar to the rti a5 setup? If that is true wouldn't the a5 and a7 really only have 1 true midrange driver? So the a7 would be better? I'm just guessing help please.
    edited July 2009
    It really depends on what you're talking about.
    If you want to listen to music in two channel, both the A5s and A7s are too bright and forward compared to the A9s--the most musical in the series.
    The point on the larger speakers is not that you would cross them over and run them as SMALL in an HT setup, but that you WOULD RUN THEM IN PURE AUDIO 2 channel in a MUSIC set up!!! As a FULL RANGE SPEAKER! That's why you buy those.
    If you're mostly HT A5s are fine and A7s OK...but if I were going A7s I'd think, hey may as well go with the flagship and have the best of HT and MUSIC! That's why I pass over the A7s myself. It's as bright as the A5 (which I'm not a big fan of). I feel the array/crossover of the A9s tones that tweeter DOWN. I mean that tweet is fine for HT...but for music IMHO...too forward, too bright. But that is, of course subjective. I HATE bright in any tweeter....even in a 50K dollar speaker--don't care for it?
    But some people like 'detail'...the question is when does detail become too harsh? That's for YOUR ears to decide. Mine have already made up their mind.
    cnh
  • 1fastz28
    1fastz28 Posts: 122
    edited July 2009
    i have a7's and have had them for over a year, and i absolutely love them
    setup
    Panasonic 46pz85
    Polk RTi A9's
    Polk CSi A6
    FXi A6's
    Energy s12.3 sub
    Denon 3808ci
    Pioneer elite dv-79
    Monster 1850
    Denon dp500m w/ grado green
    PS3,XBOX 360, NES
  • jguru
    jguru Posts: 1
    I am starting with a new setup - I have onkyo sr 607 and a pair of monitor 30 so far
    I am planning to buy rti A5, is it ok to mix them with monitor series speakers?
    I need a pair of fronts for < 300 and a sub < 150$
  • Todd Lee
    Todd Lee Posts: 73
    If you're going to use them for surrounds, then it should be fine. It's not as important to voice match surrounds, it's the front sound stage that matters most.
    Pioneer 1018
    Polk RTIA5's
    CSIA6
    RC80I's
    SVS PB12-nsd
  • Sherardp
    Sherardp Posts: 8,038
    I would say A9s. For awhile I was driving my RTi12s with just a receiver. Also check out Polk's Ebay store, a pair of A9s were listed for 899 just a few days ago. That's one heck of a deal if you ask me.
  • guinsdan
    guinsdan Posts: 37
    I vote A5's and put the extra cash towards sub(s) or something else (unless money isn't an object). Polk direct sells the refurbed A5's on eBay for around $460 shipped (check frequently or call them). Kingpinav has a set of floor models w/out grilles for $330 shipped. The 7's are $715 from direct and the 9's are $1,035.
    I'm waiting for my 5's to arrive, but I have the 3's in the front with the BIC F12 sub for bass and it sounds really good considering they aren't towers. You could pick up a sub first and see what it sounds like with the FXi. You could also consider two small subs if you really worried about bass.
    The good news is you will end up upgrading in a few years anyways once you become an audiophile and they will hold their value. Then move the 5's to the rear and get 9's (or something like that)...
    f: RTi A5
    c: CSi A6
    r: RTi A3
    s: BIC F12
    r: Integra DTR 6.9
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    I have a pair of a9's and 2 pair of a7's in the house, i auditioned the a5's before my purchase ;)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
