Noob Needs Help w/Speaker ID
vinylhunter
vinylhunter Posts: 3
edited July 2009 in Vintage Speakers
Recently bought a pair of Monitor 7cs. Although working OK, I saw a cap upgrade kit on eBay and thought it was probably time (that and I wanted to solder something). Install went fine, though I wasn't positive it made all that much difference. Now, here's the bad part. In looking at the Polk website, it appears I may have the Series 2 speakers. Mine have a tag on the back saying Monitor 7 Series, but have the SL2500 tweeters. The upgrade kit says, in big red letters, not compatible with Series 2. So, wondering if they are indeed Series 2. And, of course, where to go if I've trashed the original caps and need to pull out the new ones.
Post edited by vinylhunter on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    Welcome to Club Polk, got any pictures? Maybe some can chime in to tell you exactly what you got if youre still unsure.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited July 2009
    First off Welcome to Club Polk
    Too bad you didn't find this place before the kit purchase.
    Use the Search function here and you'll find a lot of info on the re-build. Everything matters and the folks here will help you out.
    Here are 3 good places to start looking at capacitors and resistors. Get the Mills resistors from Sonic Craft and you have a lot of options on the Caps.
    Do a little research and come back with any and all questions.
    http://www.madisound.com/index.php
    http://soniccraft.com/
    http://www.parts-express.com/home.cfm
  • vinylhunter
    edited July 2009
    OK, let's do pics. Here's the speaker, the label, the crossover with new kit installed (high- and low-pass cap), and the parts removed.
    heiney9 Posts: 25,497
    edited July 2009
    You could have done much better than what that guy on e-bay is selling parts for.
    Sonicaps
    ClarityCap
    Solen
    Dayton
    all would have been better choices. Why didn't you replace all the caps? Maybe you did and the photo doesn;t show it.
    I would have used Mills non-inductive resistors as well.
    This what I'm talking about..........my 5B's when I did the upgrade. 7's have the same parts, just a larger cabinet and PR.
    http://www.polkaudio.com/forums/showpost.php?p=613756&postcount=1
  • hearingimpared
    hearingimpared Posts: 21,136
    edited July 2009
    Welcome to Club Polk vinylhunter. I like your screen name.
