Pin Blade I/C connectors
Boywonder
Sorry in advance if this is old hat, but are these Bang & Olufson Pin/Blade connectors compatible with Polk SDA's?
They are apparently std. DIN type plugs for audio.
If they are compatible, they could be used to make a simple and cheap I/C cable without modifying the mating terminal cup connector.......just curious.
http://cgi.ebay.com/4-Bang-Olufsen-2-pin-DIN-Speaker-Connectors-Plugs_W0QQitemZ270425701253QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef6a0bb85&_trksid=p3286.c0.m14&_trkparms=65%3A1|66%3A4|39%3A1|293%3A1|294%3A200
Post edited by Boywonder on
Those don't look like they'd fit in the P/B sockets on my SDAs.
