Spikes not **** in properly
kevhed72
I have a pair of RTIa9s still under warranty, and got finally got around to installing the floor spikes. On 2 of the grey "feet", the spikes would not thread in properly / at all. Can Polk send me out 2 new grey feet for these speakers, so I can spike them properly?
please advise...
please advise...
Post edited by kevhed72 on
Hello,
No problem, just email me your address at polkcs@polkaudio.com and we can send them.
Regards, Ken -
Kenneth Swauger wrote: »Hello,
Regards, Ken
Good looking out Ken, man I love Polk, lol.
HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
How's that for Customer Service?Michael
NORTH of 60° -
Outstanding....this is why I have owned only Polk speakers for the past 16 years or so...I'll send you my adress via the link you provided.
Thanks again... -
hey kev, how are you working on those feet btw.I get real nervous about tilting them and worry about breaking the feet, or ripping the feet screws from the wood. When adjusting speeker placement, I literally bear hug the speeker and pick it strait up. is there an easier way?panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
superjunior wrote: »hey kev, how are you working on those feet btw.I get real nervous about tilting them and worry about breaking the feet, or ripping the feet screws from the wood. When adjusting speeker placement, I literally bear hug the speeker and pick it strait up. is there an easier way?
My A-9's are on hardwood floor's, so no spike's. But i do the same thing, "bear hug" the speaker's for any kind of placement. Cant think of any other way that makes me comfortable.
Maybe Polk should have provided a small hand truck for these beast's!:D
Pat.Receiver: Pioneer Elite SC-05
Amp: Emotiva Xpa-3
Front L/R: POLK Rti-a9s':D
Center:POLK Csi-a6
Rear surround's:POLK Rti-a1s'
Sub: Klipsch Synergy sub-12
Sony Kdl-46w4100 46" LCD
PS3
Audioquest type 4 wiring. -
maybe consider removing all of the spikes
and buy or fabricate a "spacer" that will work
better and be stronger (you own customizing)
I have seen machined aluminum or brass that provide
"isolation" used for turntables and other sources.
Usually for speakers some sortof dampening / deadening material used.
