Cant decide which amp to get...Plz help
Jason C Bolt
Jason C Bolt Posts: 8
edited July 2009 in Car Audio & Electronics
So this is pry a silly question but i have a RF P3 D212 and need an amp for it. Im semi broke so the cheaper the better. Im stuck on these 3.
1. http://www.katerno.com/detail/s/72765/p/HIZXI1006/Hifonics-ZXi-1006-2-Channel-2000-Watt-A/B-Class-Zeus-Amplifier-
2. http://www.millionbuyplus.com/view_product.php?itemno=HIFBXI610
3. http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/7112100/vpcsid/0/SFV/30046/sret/18111619181716223282213218283216219216287220227220291222239238297226237232227228235246247240251244237
Is it smart to go 1000 watt rms for the p3? Ill possibly be adding another sub latter... Another question i have is whats the difference between the class's of amps? Example class a, b, d etc.
Thanx,
-Jason
Post edited by Jason C Bolt on
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2009
    The first one looks good, but it's class A/B which means it will draw a LOT of power.
    The different classes are the type of amplifier it uses. A is generally regarded as the cleanest, but also the most inefficient. It will use a ton of power. B is almost never found by itself, usually in a hybrid with A - A/B. A/B is very clean and a little more efficient. These are "high current" amplifiers that are very powerful.
    Class D is the most efficient generally speaking, usually made for subwoofers because the distortion created by class D is outside the frequency range of subwoofers. These will draw less power for a given amount of wattage.'
    P.S. - Why did you start two threads with the same basic question?
    Main Surround -
  • Jason C Bolt
    edited July 2009
    So id have to upgrade my wiring (big 3) if i went with number one? And will giving my sub 500 watts over its rms be bad for it?
  • nguyendot
    edited July 2009
    Too much power won't hurt it as much as too little power.
    Main Surround -
  • Jason C Bolt
    edited July 2009
    Good point on RF's reccomendation. I wasnt sure about the whole ported thing cause of that. My buddy was tellin me that ported are always better but i see now after researching that not always the case.
