Check out my new DIY speakers
Just finished these speaks.
http://www.1414audio.com/Recession_Buster_Speakers.html
They sound fantastic powered from my 3875 gainclone as well as my 10wpc Super T-Amp. In one of the pics you will see my Polk Monitor 5's sitting to the side.
DIY is fun!
DIY is fun!
My journey: http://www.1414audio.com/
Sweet-Congrats good looking speakers.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Very nice."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
interesting.....
Very nice. What wood and finish method did you use for the cabinets?Wristwatch--->Crisco
3/4 MDF for cabinets.
10mil paper backed Birch veneer applied with DAP contact cement. Sanded with 150, then 220 to remove paper and glue left by the flush trim bit I used on my router.
One coat Minwax Prestain.
One coat Minwax Red Oak 21.
Two coats Minwax Polyurethane.
The poly was the hardest part to get perfect (and it's not). I applied the first coat with a rag then lightly sanded using 220, removing dust with tackcloth. I applied the second coat with a brush. I then took a paper bag wrapped around a wood block and rubbed everything again. This seems to take out any micro small dust particles ans bubbles.My journey: http://www.1414audio.com/ -
Looks Great, Towers Next??
Congrats,
Larry. -
TOOLFORLIFEFAN wrote: »Looks Great, Towers Next??
Congrats,
Larry.
Actually I going to make a sub to go with these next. I almost have enough birch veneer left over to make a 15" box. Most likely I will use a 10" driver and cheap plate amp from parts-express. This is what gave me the idea: http://diyaudioprojects.com/Speakers/MAW-10/MAW-10.htm the driver is no longer available so I need to spend the time finding something similar.
Anyway I'm **** around with RoomEQWizard now so this will keep me busy for awhile.My journey: http://www.1414audio.com/ -
Nice build!
Regards,
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
That birch looks great. I'm guessing those crossovers/plates are from a kit also?
davidfmartin wrote: »Actually I going to make a sub to go with these next. I almost have enough birch veneer left over to make a 15" box. Most likely I will use a 10" driver and cheap plate amp from parts-express. This is what gave me the idea: http://diyaudioprojects.com/Speakers/MAW-10/MAW-10.htm the driver is no longer available so I need to spend the time finding something similar.
Those look great David ! REW does have a learning curve but once you have it figured out it is a handy tool to have.
Look forward to your DIY sub.Speakers: SDA-1C (most all the goodies)
Yes the drivers and xovers were the first version of this:
http://www.madisound.com/catalog/product_info.php?products_id=8525
Still going for 59.00!
I am trying to teach myself electronics so I have been a real solder head lately and in this project I wanted to experience the woodworking side of the house and didn't want to solder anything
If you want to see some of my other builds go to http://www.1414audio.com/ and click "Project Builds".My journey: http://www.1414audio.com/ -
wow! great work2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
Pioneer Elite vsx-40
BJC cable -
...great JOB ! Nice finish work. Did you build the stands too?
No, I had those already.My journey: http://www.1414audio.com/ -
One thing that I find that makes a good finish but takes a long time is double boiled lin seed oil, same thing that they use on gun stocks. Being a veneer it might not take as long as a gunstock. once you have 4 or 5 coats of lin seed on then you rub it down with burlap. Rub hard enough to create a little heat. You get a really nice finish that is dust free. Then when you clean you speakers take a soft ,lint free clothe with a touch of lin seed oil and give them a quick rub.
***make sure that you use doouble boiled*** -
Great job on the speakers. I just ordered a set for myself. This will be the first speaker build for me. I think I will try to veneer the cabinets.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
I broke down and ordered one the RB2 kits.I don't need any more speakers but at that price why not.Testing
Testing
Testing -
Wow....I just looked at the price. That is a phenomenal price. I don't know how they are making money at those prices.Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
Nice job!!"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
The reason I wanted to avoid an oil finish is what I perceived as maintenance. I live in a very dry climate (Lakewood, CO.) and didn't want any up keep. My assumption was that an oil finish would require a rub down from time to time and I don't even dust
David,
Thank you for letting me audition these beauties! (I had the privilege of hearing them a couple of weeks ago when I bought a pair of RTi4s from David--Thanks again for those, I love 'em). Anyway, very nice job on these. They look and sound fantastic! Also, good to find you on the forum after having met you in real life.
Best wishes,
Chris -
David,
Best wishes,
Chris
Thanks! Glad you are enjoying the RTi's. Even though I'm in to DIY, I will always have a pair or two of Polks around the house
