Electrical gurus chime in...
edbert
edbert Posts: 1,041
edited July 2009 in The Clubhouse
A switch in the controls for my ice maker has gone out and I need to replace it. First, can I purchase this locally for a decent price and if so, where would I look(DFW area). Second, if the prices are too high locally, could I order this from PartsExpress even though mine is 5A at 125 or 250VAC?
Thanks!
Eric
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff.
Post edited by edbert on
  • edbert
    edbert Posts: 1,041
    edited July 2009
    Thanks! Too bad NJ isn't closer to TX. Is this something Radio Shack would have or do I probably need to find an appliance parts place around here?
    Pioneer VSX-816
    CS1 - center
    XBOX
    SOPA since 2008
    Here's my stuff.
  • snow
    snow Posts: 4,337
    edited July 2009
    edbert wrote: »
    Actually thats probally a good thing, could you imagine mating the best/worst customs, foods, personalities etc of the two together :D
    REGARDS SNOW
  • Sami
    Sami Posts: 4,634
    edited July 2009
    edbert wrote: »
    You could try Fry's.
    This seems similar but doesn't have any detailed description online: http://www.frys.com/product/2314329#detailed
    The closest to you might be their Plano location: http://www.frys.com/isp/plano.html
  • edbert
    edbert Posts: 1,041
    edited July 2009
    Thanks Sami. Totally forgot about Fry's. I know exactly where that one is in Plano. I'll head there in the morning.
    Thanks gents for the quick responses. This will make the Mrs. extremely happy.
    Pioneer VSX-816
    CS1 - center
    XBOX
    SOPA since 2008
    Here's my stuff.
  • maximillian
    maximillian Posts: 2,144
    edited July 2009
    You need to ensure proper electrical rating (your alternatives are good) and proper mechanical fit. I would try a local appliance repair store first. The manufacturer of the icebox will have a list of repair locations either on their website or give them a call. They should have one in most major cities.
  • edbert
    edbert Posts: 1,041
    edited July 2009
    Thanks Max. I took a picture of how everything looked before I took it out so I would know how to put it back in. Either way I know a guy that runs an appliance parts store, but he's out in AZ now and the store here is not as close as Fry's.
    Pioneer VSX-816
    CS1 - center
    XBOX
    SOPA since 2008
    Here's my stuff.
  • Gadabout
    Gadabout Posts: 1,072
    edited July 2009
    Before you buy a switch you need to see if the one that is installed is normally open or closed. My guess is; it is normally open and when the switch is activated closes the circuit.
    There are also the micro switches that can be either (normally open or closed). They have a third lug and depending on where you hook up the wires determines which way the switch operates.
    Fry's might have what your looking for (as Sami said). Match the amps, and check the operating conditions and see if it has a valid temp rating for where the switch is located.
    Also, usually a quick call to the customer service folks of your fridge manufacturer with the model # will have them shipping you a new switch.
    Hope that helps,
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • edbert
    edbert Posts: 1,041
    edited July 2009
    Thanks! I actually got it fixed and it is making ice! The previous switch was a 5 amp and the new one is a 15 amp. There are a total of three switches in an icemaker. Two are like the one that I had to replace and the other is slightly different. Either way, everything is in good working order and the wife is happy!
    Pioneer VSX-816
    CS1 - center
    XBOX
    SOPA since 2008
    Here's my stuff.
