Is a Memphis 2400 Watt to Much
ChevyMan4x4
ChevyMan4x4 Posts: 52
edited March 2003 in Car Audio & Electronics
Is the memphis 16-MC2000D too much power for 2 Polk GNX 12's? Find the stats at the link below Thanks!
http://www.memphiscaraudio.com/P08&09_MClass_Amps.htm
:confused:
Sir Daniel X. Boom - the GNX slayer
Post edited by ChevyMan4x4 on
  • CPHILHOWER
    CPHILHOWER Posts: 343
    edited March 2003
    1200 Watts at 4 ohm, 2000 at 2 ohm. I would have to say most definately YES. GNX 12" is rated up to 175 watts rms each. If you paralleld them they would each see 1000 watts.
    Chris
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited March 2003
    dude memphis is not pyle here....
    a 25,0000000000 watt pyle amp might work on some GNX's, but memphis is a good quality reputable company that when they say their amp does 2000 watts it does at least 1900 and probably tops out above its rms.
    chris is right -- 1 grand on a GNX will just about blow it out of the box.
    200 per sub is more like it.
    The Artist formerly known as PoweredByDodge
