Trigger question
POIDOG
Can a single trigger output be split with Y to power up 2 external amps?
Post edited by POIDOG on
Yes, as long as the trigger can handle the load. Most triggers are rated about 100ma. Also make sure both amps use the same pin for +.
Thanks for the info.
