impedence
emf28
emf28 Posts: 4
How can I tell what the impedence is on my speakers?
Post edited by emf28 on
  • dekuda
    dekuda Posts: 756
    edited July 2009
    You need a meter that would measure resistance and place one lead on the positive and one on the negative terminal of your speaker.It would help to include the model so we could help answer!
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
  • emf28
    emf28 Posts: 4
    edited July 2009
  • TNRabbit
    TNRabbit Posts: 2,168
    edited July 2009
    What's the big question; WHY do you need to know?
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Solumnus
    Solumnus Posts: 48
    edited July 2009
    The RTiA3's are 8 ohm speakers. I'm pretty sure all Polk speakers are 8 ohms, with the exception of the LSi line, which is 4 ohms. hope it helps.
    Toshiba 62HMX85
    Panasonic DMP-BD60
    Xbox 360 with HD-DVD
    Pioneer VSX-9130-TXH-K
    Polk Audio CSiA6
    Polk Audio RTi10's
    Polk Audio RTi4's
    Polk Audio RTi6's
    Polk Audio PSW505
  • CoolJazz
    CoolJazz Posts: 572
    edited July 2009
    Actually a typical Volt-Ohm-Meter (or VOM) that measures DC resistance isn't the right thing to determine impedance at all. You need to make AC measurements to look at impedance.
    DC, is of course 0hz, which we spend little time listening to...depending on your favorite musical style. :p As frequency varies, so will the impedance measurement. An 8 ohm rated speaker system may very well have some frequencies where 30 or 40 ohm values are measured.
    And just to make it more confusing, the actual power needed is dependant on not just the impedance, but the simultaneous phase angle of the load and the rate of change of that. That's why one 8 ohm rated speaker can be run by a lower powered amp, while another equally 8 ohm rated speaker may be notoriously power hungry and bring an average powered amplifier to it's knees.
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • zarrdoss
    zarrdoss Posts: 2,562
    edited July 2009
    They all vary, most of the older Polk's and most of the sda line are 6 best way to be sure is research it or check with an multi-meter.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited July 2009
    zarrdoss wrote: »
    Exactly, multimeter is the tool to use while an ohmeter is also adequate. It is a fact that the coil impedance will vary with different frequencies however, the rating of a speaker is measured when idled, that is the impedance reading that is of importance when trying to match with an amp.
    You could also use a search engine for the actual specs or even user manual. IE: http://www.google.ca/search?hl=en&q=RTi+A3%2Bspecs&btnG=Search&meta=, http://www.google.ca/search?hl=en&q=RTi+A3%2Buser%2Bmanual&meta=. Of course, if you know the brand you can usually inquire for the specs/manual on line. Even 30 -35 years old speakers can often be successfully researched on line even if the company doesn't even exist anymore.
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • gmb2428
    gmb2428 Posts: 40
    edited July 2009
    Tech support said my RTi line can dip to 3.5 ohms!
  • slowpolky
    slowpolky Posts: 714
    edited July 2009
    like rti6? 8's ? or csi5 ?
    would these lil speakers dip lower than 8
  • CoolJazz
    CoolJazz Posts: 572
    edited July 2009
    TECHNOKID wrote: »
    Exactly, multimeter is the tool to use while an ohmeter is also adequate. It is a fact that the coil impedance will vary with different frequencies however, the rating of a speaker is measured when idled, that is the impedance reading that is of importance when trying to match with an amp. TK
    Good night!! :confused: English is the only language I know and since it's obviously failed to communicate the difference between AC and DC, I'll get back to you in a couple of years after I learn French. :D Maybe that language will better explain it!!
    But if there is a confused noob reading this thread in the future that does understand English...an ohm meter or an ohm reading on a multi-meter (same thing folks!) is a DC reading! Tells you nothing at all about an AC impedance value. :p
    CoolJazz
  • apphd
    apphd Posts: 1,514
    edited July 2009
    EMF, Welcome to CP. To eliminate any confusion or doubt here is a link, you were only a couple clicks away.
    http://www.polkaudio.com/homeaudio/rtia/specs.php#bookshelf
    As others have told you 8 ohms, and the impedance is given at a nominal value because it will vary with freq.
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2009
    CoolJazz wrote: »
    CoolJazz
    Incorrect.
    With the coils static - the AC and DC resistance will be exactly the same.
    A standard multimeter will do fine for the static impedance value.
    Measuring the dynamic impedance will be a bit more difficult.
    Main Surround -
  • CoolJazz
    CoolJazz Posts: 572
    edited July 2009
    :eek:
    nguyendot wrote: »
    Incorrect.
    OK. If that should be true...then why would a DC resistance measurement always be lower than anywhere on an impedance sweep? How would you choose to relate the typical 3-4 ohm DCR to an 8 ohm speaker? That makes no sense on any level.
    What AC frequency are you going to use to compare it to DCR?
    Come on...this is the first few minutes of the first day of Electronics 101! :confused:
    And WTH is a static impedance value anyway? You either are measuring it with a signal across it or not. A coil laying in the corner with no signal across it really has a value in all cases of a million zillion ohms. Prove otherwise!! :eek:
    Again...DC resistance is listed in an ohm value, that's where the relationship with impedance ends!!
    CoolJazz
  • Face
    Face Posts: 14,340
    edited July 2009
    Want to know a speaker's true impedance?
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=390-803
  • hearingimpared
    hearingimpared Posts: 21,136
    edited July 2009
    Welcome to Club Polk emf28.
  • TECHNOKID
    edited July 2009
    CoolJazz wrote: »
    CoolJazz
    Sorry but I don't see what you are talking with AC DC? I only acknoledge previous post mentionning the impedence change with various frequencies. I do not understand the French comment(s) on AC DC as AC DC are English correct abreviations. AC = Alternative Current while DC = Direct Current. French = Courant Alternatif etc... so I do not understand your point. Also, while my French may play tricks on me, allow me to correct you as an ohmeter = measure resistance/impedance solely/only and a multimeter = reads/measures either volts, ohms/impedance, current, in some more elaborate/expensive ones it could even possibly read lower frequencies, measure/test diodes and even possibly transistors. Multi stands for multi purpose meter. All in one if you prefer.
    Cheers!
    TK
    DARE TO SOAR:
  • TECHNOKID
    edited July 2009
    Face wrote: »
    Hummm, very interesting innexpensive tool! Thanks for the info!
    Cheers!
    TK
    DARE TO SOAR:
  • nguyendot
    edited July 2009
    After some reading i retract my statements :)
    Main Surround -
  • TECHNOKID
    edited July 2009
    You would measure with such a tool as Face suggested, it isn't neither an ohmeter nor a multimeter.
    Measure speaker parameters
    "Woofer Tester"
    http://www.woofertester.com/sales/wtpro.pdf http://www.woofertester.com/sales/st.pdf
    Ohmeters/multimeter and woofertester/speakertester are totally different tools and have totally different applications.
    DARE TO SOAR:
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    this is like Home Improvement for Speakers
    all these neat tools
  • TECHNOKID
    edited July 2009
    jvc wrote: »
    The one that Face provided is ratter innexpensive if of course you already own the laptop. Nice toy/tool however, if too expensive many of us wouldn't be able to justify the expense. This is more technical, engeneering like which most hobbier really don't need. Knowing the nominal impedence and properly match with the appropriate amp is the basic for proper and efficient set-up. If one has the knowledge, money and willingness to experiment with such tool is great otherwise it is useless to most.
    Cheers!
    TK
    DARE TO SOAR:
  • CoolJazz
    CoolJazz Posts: 572
    edited July 2009
    A couple of models of a true impedance meter...
    http://www.mcmelectronics.com/product/72-6947
    http://www.toaelectronics.com/zm-104.asp
    Both just simply measure at 1khz. No other frequencies...though at 1k you will typically get pretty close to knowing the rated value. As you go higher in frequency, the actual impedance value does rise slowly in the typical driver.
    A functional, if not extremely accurate way to measure a speakers impedance can be done this way...
    - Connect about a 50 ohm pot in series with the driver voice coil and then to the amp.
    - Connect a frequency generator or CD player with suitable test CD in it to the amp input, keeping the level pretty low to begin with.
    - Start walking up the frequency scale in steps. For each step, measure the voltage (has to be AC!!) across the voice coil terminals and then across the pot.
    - Adjust the pot until both voltages match.
    - Now shut down the amp and measure the resistance across the pot. This is the driver impedance for that specific frequency.
    - Repeat the measurement for each frequency you want to know the actual impedance for.
    Teknokid...don't scratch your head too much on the reference to French. I was trying to kid and that doesn't always come through the web very well. The point though is to not leave the information laying around that would lead people to believe they can pick up a multi-meter and read the impedance of a speaker.
    I still don't understand the reference to dynamic or static measurement though. That sounds like stuggling to explain something that can't be explained. I immediately visualized someone walking down the road, whistling along, with ice skates thrown over their shoulder, headed towards the farm pond...in the middle of the summer! :eek: :eek: This can't lead anyplace good!!!
    Again, the typical meters ohm measurement is a simple DC measurement and is not the same thing as measuring impedance which is an AC measurement for which you must pick a frequency.
    CoolJazz
  • megasat16
    megasat16 Posts: 3,521
    edited July 2009
    Impedance in a nutshell is the combination of both the Resistance (R) and Reactance (X) in the AC circuits.
    For the speakers made of single speaker driver or multiple drivers will have a Crossover Networks (aka filters) which contains resistors, capacitors, inductors; etc. will have varying Reactances (capacitive, resistive or inductive) depends on the frequency of the AC signal in used.
    Generally, the impedance of a loudspeaker is given by the manufacturer. It's usually is the average value from the impedance curve generated over a spectrum of frequency (20Hz-20KHz). The phase angle is never given out as numbers since it means little sense to the general consumer. But a handful of manufacturer provided the RTA (real time analyzer) analysis of the impedance curve and the phase angle of their speakers in the graphical form.
    Since most manufacturer provided only a mean or average value of impedance curve, the actual impedance of the speaker could be lower for some frequencies and will be higher for the others.
    If you want to truly understands the impedance and phase angle of current vs. frequency, you'll need an Oscilloscope (either Digital or Analog), An Amplifier, a Signal Generator, and RTA (Real Time Analyzer). And true impedance needs to be measured for the minimum of 20Hz-20KHz frequency spectrum.
    But CoolJazz provided a functional method for measuring the impedance without the necessity of the expensive test equipments.
    And I concur with CoolJazz that you can't use multimeter to measure true impedance of the loudspeaker. The multimeter measurement of a voice coil of the speaker driver is resistance only and it's only applies to DC measurement.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
