Phono Cartridge Alignment
jimmydep
jimmydep Posts: 1,305
edited July 2009 in Electronics
I just installed a new cartridge on my TT. Any suggestions on how to align the cartridge properly. I'm thinking I'll have to get an alignment guage to do it right.
Is there a way to align the cartridge without an alignment tool?
Jimmy
Post edited by jimmydep on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited July 2009
    billbillw Posts: 7,543
    edited July 2009
    jimmydep wrote: »
    Jimmy
    You can't do it without some type of alignment tool. Some turntable/tonearms come with a jig that lets you adjust until the stylus point is in a certain point. Most people just use a 'null point' protractor. (which can usually be downloaded and printed for free)
    Most of them are designed for 2 points (inner and outer) which minimizes distortion for most tonearms. You adjust until you get it aligned to both points. The two null points really depends on the tonearm lenth/curve/etc. What kind of TT are you aligning?
  • jimmydep
    edited July 2009
    billbillw wrote: »
    I have an old Sony PS-4300 it has an S shaped tone arm....I know the TT is old but it's in immaculate condition and works and sounds very nice.
    Thanks for the advice
    Jim D
    edited July 2009
    I'd just go to vinyl engine and download a free protractor. Use the ones called "stupid protractors" and cut out the Baerwald one. It should get you pretty close.
    http://www.vinylengine.com/cartridge-alignment-protractors.shtml
    (you may have to register to get access, but its worth it because its free, and you have access to hundreds of manuals and brochures).
  • jimmydep
    edited July 2009
    Thanks, I downloaded the protractor (I didn't have to register) it was easy to use, and took about 20 min and a large magnifying glass to get it right.
    Thank you for all your help, it sounds better than ever now.
    Jimmy D
