Bren1 turntable clamp
haimoc
haimoc Posts: 1,031
edited July 2009 in 2 Channel Audio
I was looking a turntable clamp to replace a cheap clamp that comes with Denon DP-500M. I found an Audiogon ad for Bren1 turntable clamp with great price and excelent looking finish, so I decided to try the standard one.
Scott (www.bren1recordclamp.com) shipped the order very quickly with no problem. The Bren1 standard turntable clamp's build quality is top notch with excelent/fine finish; however, it is a bit tall for the turntable cover. So, I asked Scott to exchange it for a lighter version (Lite... ¼” lower profile, 1.5” on Lite vs. 1.75” on standard. The diameter is the same). It is no problem with Scott to offer a free exchange quickly. I received the Lite version and it worked with Denon DP-500M perfectly (with the turntable cover down).
I think he deserves a good recommendation to all who are looking for a fine turntable clamp and don't want to pay much money.
I posted a few pixs for your reference.
Post edited by haimoc on
