Question about center channel placement?
ky_polkie
ky_polkie Posts: 48
edited July 2009 in Speakers
This is driving me crazy and I was hoping someone could help me out.
As you see below my theater setup is suboptimal for a center channel.
I now have a pair of RT55i on the middle shelf to each side of my TV. The RT800i you see in the picture are now gone.
I also now have only 1 CS400i which I have on the top left shelf.
The problem I have is that the center sound is obviously not coming from the center of the screen. There is not enough room in front of the TV for the center channel.
Any advice? Has anyone run into a similar scenario?
Post edited by ky_polkie on
  • Conradicles
    Conradicles Posts: 6,143
    edited July 2009
    You could ditch the center for now and go phantom. It works good if you set your AVR up properly. Nice system by the way.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited July 2009
    You could use something like this B-tech center channel wall mount...
    http://www.amazon.com/B-Tech-Center-channel-speaker-mount/dp/B0002YCKLQ/ref=sr_1_2?ie=UTF8&s=electronics&qid=1247023508&sr=8-2
    ...and mount it on the wall above the TV. You'd want to angle the speaker downwards a bit so it's pointing towards ear level, rather than firing above your head.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Conradicles
    edited July 2009
    But it would look horrible Curt.
  • ky_polkie
    ky_polkie Posts: 48
    edited July 2009
    Thanks for the reply. Optimally I would like to use a center channel.
    Like I said I have the RT55i and CS400i up front now.
    I have a Denon AVR-3806 receiver.
  • ky_polkie
    ky_polkie Posts: 48
    edited July 2009
    I'd have a really hard time passing that one by the wife. But it is an interesting idea.
    BTW --- getting a smaller TV is NOT an option!
  • comfortablycurt
    edited July 2009
    That's a matter of opinion.;) I think it would look just fine myself.
    You could always put the center channel in the fire place...:p
    ky_polkie wrote: »
    Just don't even tell her about it. Install it while she's at work, and convince her that it's always been like that...lol
    edit-I just realized how hard it would probably be to run the wire for the CC in the wall...that's probably not really an option after all.
  • Conradicles
    edited July 2009
    What you could do is build a cubby into the wall above the TV if you are good with Sheet Rock. Then angle your center down as Curt said and all is well.
  • comfortablycurt
    edited July 2009
    That would probably be your best bet, and would probably yield the highest WAF.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2009
    I consider a Polk in wall speaker painted to match wall, above TV.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2009
    If you slide the TV all the way back how much room would you have in front of the tv?
  • BeRad
    BeRad Posts: 736
    edited July 2009
    Well, You could always build out from the wall above the TV. Given that the TV/Fireplace is extending beyond the shelves on either side, a section extending another 8 inches above the TV wouldn't look that bad as long as you brought it right up to the roof. Also make it more narrow than the section the TV/Fireplace is in.
    Build the frame with a plywood compartment for the speaker. Mount it, drywall it, tape and paint. (don't forget to get that cable up in there before you finish it! :)
    Wow... I just read what I typed. If you can follow that you are a better man than I.
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2009
    Whats behind that wall directly above the tv?
    If nothing, since it sticks out from the wall - cut out a hole and slide the center in there.
    Main Surround -
  • kcoc321
    kcoc321 Posts: 1,788
    edited July 2009
    I would second or third that..it would be the cleanest.
    Buy a basic cabinet from a Home Improvement Center of your choise and paint it to match the rest of the trim.
    Easy Saturday project. If you cut the hole right you would not even have to do any sheetrock patching.
    Also remember to run 'smerf' tubing ie 2" pvc tubing to the tv area, so you have easy wiring access.
  • ky_polkie
    ky_polkie Posts: 48
    edited July 2009
    I have thought about the cubby idea as well. I'm just worried it won't look perfect.
    I believe that behind the wall it is an empty space. The fireplace is gas so there shouldn't be anything back there as far as a chimney goes.
    I also think that an in-wall center is an idea that is growing on me.
    The cheapest in-wall Polk center seems to be list price of $649. That's simply too much for me.
    I have used monoprice's line of in-wall speakers in a few of my friends' home theaters and am really impressed with their sound. It won't exactly timbre match my RT55i but then again neither would a new Polk center.
    Monoprice center: http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10837&cs_id=1083704&p_id=4930&seq=1&format=2
    Since the Monoprice center is only about $50 I might install it and just see which one I like better. If I don't like it it would be easy to make the hole a little bigger and build a cubby.
  • ky_polkie
    ky_polkie Posts: 48
    edited July 2009
    leroyjr1 wrote: »
    5-6" max.
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2009
    Are there any other rooms you can use for a HT? For example, I use a spare bedroom. You need to get the TV off the wall over the fireplace. It looks nice for pictures but is terrible for watching TV. Bring it down to eye-level. How is the room designed? What is the wall opposite the fireplace like? Get a TV stand, put the L/R speakers to either side and the CC under/over the TV. It all depends on whether you want a HT, or a pretty setting that is terrible for TV/HT. Otherwise, do as others suggested and mount it inside the wall above the TV, and angled down.
  • nguyendot
    edited July 2009
    Just buy a matching center off ebay or craigslist and cut a hole. Stretch some grille material over the hole...dye it to match the wall color.
    Main Surround -
  • ky_polkie
    ky_polkie Posts: 48
    edited July 2009
    BlueFox wrote: »
    No other rooms for HT. The wall opposite the fireplace is actually not much of a wall at all --- it is an open kitchen.
    I bought the house with the hole above fireplace already there. It actually isn't that bad as far as watching movies goes but it is definitely not ideal for HT.
  • ky_polkie
    ky_polkie Posts: 48
    edited July 2009
    nguyendot wrote: »
    Do you mean in-wall center? If not I already have a CS400i.
    What would be a timbre matched in-wall center for the RT55i (if any?)
  • nguyendot
    edited July 2009
    Just use your CS400i.
    Cubby hole it. If you're afraid of the hole, just stretch matching grille cover over the hole.
    Main Surround -
  • ky_polkie
    ky_polkie Posts: 48
    edited July 2009
    nguyendot wrote: »
    I am going to have to cut drywall, reframe horizontally to reconnect the studs, build a shelf to tilt the center down a bit, trim it out and then paint.
    That seems like a lot of work but it might be my only option...
  • messiah
    messiah Posts: 1,790
    edited July 2009
    Just stick it in the fireplace angled slightly up until you are able to figure out how to do it properly. Oh yeah, don't start any fires!!
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • digitalvideo
    digitalvideo Posts: 983
    edited July 2009
    You might be able to get a good deal on the CSiA5 or CSi A6 at www.highdecibels.com for around $320 bucks. You can also get the RTi A9 at highdecibels.com for around $635.
  • digitalvideo
    edited July 2009
    You could also get the Infinity CC225 2-way Classia Series center channel speaker at http://www.highdecibels.com/proddetail.asp?prod=CC225 for $245 bucks.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    Personally, I'd stick with the CS400i being that it is voice matched to his rt55's (and what looks to be like rt600/800 towers). Why buy a new center when you've got an awesome one already thats hard to come by?
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Conradicles
    edited July 2009
    Don't underestimate going "Phantom" with no center. Search this forum using the word phantom and you will see many hear use that method.
    Sounds great and sometimes better than a center when properly set up.
    Then you can sell your CS400 and make some cash.
  • Conradicles
    edited July 2009
    Then you could get som SDA-CRS+ bookshelf speakers if they will fit.;):cool:
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    nicely done.
    any room behind the TV monitor.
  • jacob.simpson
    jacob.simpson Posts: 481
    edited July 2009
    Frys has Tc610i for 49.99 each with shipping it will be less than 60$
    thats the best bet what you can take and its a polk so timbre matching will not be an issue.
  • dkmuch
    dkmuch Posts: 79
    edited July 2009
    I vote for a new hole in the wall. It matches your decorating taste. Personally, I'd raise the hole for the TV at the top, and place the center below the TV.
    But it really doesn't matter, you're not going to be able to watch movies straight through or listen at an appreciable volume for the next 2-3 years after that new baby arrives (assuming you don't add babies more after that!)
    RT55i mains, CS400i center, FX300i surrounds, RTi15 rears, Energy S10.3 Sub, Onkyo 607 / PS3
