Pre Amp and Receiver run together?
Toolfan66
Can I hook my Pre Amp and Receiver together?
If so do I just use the preouts on the receiver to external processer on the preamp?
Post edited by Toolfan66 on
Sure it's possible but what are you trying to achieve?Testing
Testing
Testing -
Tuner and Ipod dock for the wife.
In that case just hook the recievers pre out to an aux input on the preamp.Select that aux when you want to listen to tuner/ipod.Alternatively you could use the tape outputs of the reciever, in that way the output from it will not be affected by the recievers volume control,using the pre outs the volume control will be functional.Testing
Testing
Testing -
buy wife her own rig.
live happily.
RT1
