Is there a way to tell the difference...
nooshinjohn
between the mw6503 and the mw6511? My drivers in both cabinets have the magnets covered in Dynamat, and the ID tags are covered. This stuff is impossible to get under to take a peak. are there specs that can be read that will help ID the drivers? I am only concerned as the guy also wired the cabinets incorrectly when he put the drivers back in, so I must assume the worst here and figure he did not care as to what driver went where. Thanks for the help...
John
John
Post edited by nooshinjohn on
You could try gently heating the dynamat with a hair dryer, blowing away from the driver. May loosen it up enough to peel it back a bit.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
possible there is a standing resistance.
see if there is a difference using your ohm meter.
for example
6516 reads approximately 6.8 ohms
6502 reads approximately 3.6 ohms
i would be curious to know what your drivers measures -
6511 = 4 Ohm
6503 = 8 Ohm'65 427 Shelby Cobra
'72 Triumph TR-6
__________________
'88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
'86 Polk SDA CRS+
'84 Polk Monitor 10A (Peerless tweeters)
'05 HSU VTF-3 Sub (Original OEM)
'20 HSU VTF-3 Sub (three more, 100% cloned)
'93 Carver TFM-35
'88 Carver M-1.0t
'88 Adcom GFT-555
'88 Adcom GFP-555
'88 Adcom GFA-555 (upgraded/restored)
'88 Adcom GFA-555 (a second one upgraded/restored)
'05 Onkyo DV-555 media
'89 Fosgate 360 Digital Space Matrix
'89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
'91 Kenwood Basic M1D Amp
'89 Pioneer Laser Disc media
'89 Sony SuperBeta HiFi media
One PGA2310 based custom built remote volume control
Four Polk T-15's
Four Polk TSi-200's
Four Polk TSi-100's
Two Polk CS-10's -
