Problem with Audiosource 200 Amp
DForeman
I have an Audiosource 200 Amp with A/B speaker switching capabilities. The amp works fine when speakers are hooked up to the B terminals but when connected to the A terminal, music cuts out from time to time.
I've since replaced the amp with an Audiosource 100 (which is all I need for powering my deck speakers) but if I can fix the 200 for a mininmal amount I'd like to sell it.
Worth fixing?
Worth fixing?
Parasound P5 Pre
Marantz AV 7703 Pre/Pro
Outlaw 7500 Amp
Marantz SA14s1 SACD/CD
Rega Planar 2 TT
Polk Audio Speakers: LSiM 705 Fronts, LC65FX Surround, LSiM 704c
Oppo BDP-103
Outlaw 7500 Amp
Rega Planar 2 TT
Oppo BDP-103
Post edited by DForeman on
The fact that it works fine in the B position would indicate a problem with the A switch like bad contacts or cold solder joints.Testing
Testing
Testing -
Thanks GV. This is certainly something I can't fix on my own. Will probably just sell as is.Parasound P5 Pre
Outlaw 7500 Amp
Rega Planar 2 TT
Oppo BDP-103
