Speaker wire in place of jumpers question
Fud
Fud Posts: 16
can i pull the same bare wire through both posts (high and low)is it safe?if not,could i put the bare wire and the jumper wire in the same hole?
    F1nut Posts: 52,407
    edited July 2009
    If you are asking if it's ok to use speaker wire in place of the metal jumper bars, the answer is yes. In fact, it's better than the bars.
  • Fud
    Fud Posts: 16
    edited July 2009
    no,what i am asking is in the process of using wire instead of the plate.is it safe to draw the wire from the avr through both the upper and lower posts?because most examples ive seen say draw the jumper through both posts then use banana plugs for the main connection.and what if you cant draw it through both would it be safe to do the same but draw bare wire through along with the jumper wire insread of bananas?i just dont want to short my speakers or receiver.
    F1nut Posts: 52,407
    edited July 2009
    Yeah, I wouldn't have bare wire exposed anywhere.....that's simply asking for trouble and another damn good reason to use banana plugs and/or spades.
  • danz1906
    danz1906 Posts: 5,144
    edited July 2009
    Agreed,bare wire will do just fine.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • John K.
    John K. Posts: 822
    edited July 2009
    Fud, stripping enough of the speaker wire so that it would reach through both the upper and lower terminals would be safe if you were very careful to not leave a loose strand that could touch the other conductor. The more basic point, however, would be that there's no technologically sensible reason to do so. For the distance of 2-3" covered by the connecting strips, what metal is used for the connection can have no audible significance. Manufacturers certainly wouldn't sabotage their speakers by supplying a connection that would somehow harm their performance. Relax.
  • John K.
    John K. Posts: 822
    edited July 2009
    Yes, but Mapleshade is a sort of Jekyll and Hyde operation. They produce many fine records, then on the audio "products" side of the business they peddle the most absurd ripoffs for gullible audiophiles. Their claims have no factual support.
    F1nut Posts: 52,407
    edited July 2009
    John K. wrote: »
    More complete and utter BS.
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2009
    John K. wrote: »
    On the other hand, they do let you try the product, and return it for a full refund if it does not work. Personally, I have bought a few CDs, and they are immaculately recorded, and sound great, but I have not really liked any of them. However, their speaker cables, digital and analog ICs, and CD/DVD cleaning and polishing products have worked great.
  • Fud
    Fud Posts: 16
    edited August 2009
    i eventually found and put back on the jumpers and ran the wires through the low posts.bi-amped they were tighter and more energetic.but no real change in the overall sound.
