12AX7 replaces 12AU7??
BitoFrantido
BitoFrantido Posts: 2
edited July 2009 in Electronics
Anyone pulled on their 12AU7's and put in 12AX7's? :confused:
Post edited by BitoFrantido on
  • BitoFrantido
    edited July 2009
    Would 'mo gain (x7's) make a volume difference in a preamp?
    F1nut Posts: 51,786
    edited July 2009
    A 12AX7 has a gain factor of 100, while a 12AU7's gain factor is 20...not even close. Besides that little issue, the anode current and grid voltage are very different. Therefore, 99% of the time they are not interchangeable and will cause bad juju to happen to your gear.
  • george daniel
    george daniel Posts: 12,096
    edited July 2009
    ^^^^^^^^^^^^^better listen to was he's putin' down^^^^^^^^^^^^
    In some cases you can interchange them,, in most,,,nope,,check with your manufacturer before you proceed.
