RCA Jack on Adcom GFA-555
pablo_rodz
Hi all!
I just bought a used Adcom GFA-555 it's missing the right channel RCA Jack. I'm thinking of fixing this as a DIY project. How hard would this be to a noob working on electronics? I was looking for replacement jacks on Partsexpress.com, and saw some affordable ones... What do you think I should get?
Anything else, easy to "upgrade"?
Also what solder should I use for this job? there are quite a few options out there...
I will be picking up the amp soon....
Thanks in advance!
Thanks in advance!
HT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
Living Room:
Post edited by pablo_rodz on
Not really that hard to fix. I would get a totally new L+R rca pad and use rosin core solder.
Don't know of any other easy mods, and also you can get RCA inputs at your local rat-shack
http://www.radioshack.com/product/index.jsp?productId=2103224 -
thanks, but I will upgrade to gold plated RCA Jacks...
If I'm going to take the time to change them, might as well go with better.HT:
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7 -
How about upgrading binding posts? Worth it? Difficult?
And what about the power cord?
I might do the upgrades in steps, not all at once.HT:
Living Room:
I would not do binding posts or power cord, just use banana plugs IMO
Did you ever get it repaired?Main Surround -
