Spiking From Amr 130
slimZLIM
slimZLIM Posts: 3
edited March 2003 in Speakers
IM SENDING THE 2ND SUB IN FOR SPIKING. SAME PROBLEM WITH THE FIRST. THIS SHOULD NOT HAPPEN TO THE TOP OF THE LINE SPEAKER COMPANY. LET ALONE ANOTHER 20 BUCKS IN SHIPPING ON TOP OF THE 160 DOLLER SET. THIS IS MY LAST POLK AUDIO PURCHASE THAT ILL MAKE. :supermad:
Post edited by slimZLIM on
  • brettw22
    brettw22 Posts: 7,624
    edited March 2003
    Really? You're gonna boycott a speaker company because of a pair of computer speakers? Sorry to hear of your problems with that model. The problem might just be that you're asking them to do something that they're not capable of. Don't be all tryin to get tower performance from a little satellite speaker..........
  • slimZLIM
    slimZLIM Posts: 3
    edited March 2003
    IM NOT DOING ANYTHING OUT OF THE ORDINARY. THE SPEAKERS SPIKE ON THEIR OWN WITH THE PC OFF.
  • brettw22
    edited March 2003
    Frist of all.......see that button labeled Caps Lock on your keyboard? Hit it and type in lower case.......
    If the PC is off, maybe you've got a problem with the power in your place. Have you checked the wiring or tried to plug in the speakers into another outlet? I don't think that you can have 2 subs just pop if you're feeding it no signal and all that its plugged into is the outlet.........
  • slimZLIM
    slimZLIM Posts: 3
    edited March 2003
    Nice try to fix my problem, but I moved to a new house between the first sub and my new one.
    Any other ideas. Im thinking I should of purchased a cheaper set from creative labs or somthing.
    p.s. I found the caps lock button.
    thanks.:lol:
