Computer Help
GaryZ06
GaryZ06 Posts: 317
edited July 2009 in The Clubhouse
Hello Guys and Gals I have a slight problem that maybe you could help me with if possible.For some reason I can't get on a website/forum that I frequent. When I try it sends me to a blank screen or various other websites but when I try it on someone else's computer there is no problem....For the record I can get on any site I want to except this one.I am using a Macbook if this helps......Thanks in advance....I am sure it's simple but I suck at computer stuff.
Panasonic 50" Plasma + Pioneer 6010
Toshiba XA2 HD-DVD
Panasonic BD30 Blu-Ray
Pioneer 1014
Polk RTi12 (front)...Polk CSi5 (center)
Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
3 Outlaw M-200 Amps
Post edited by GaryZ06 on
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    edited June 2009
    try another browser, you probably can delete history and try again that should fix it.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2009
    Sound like you might have a redirector running (spyware). Try running Malwarebytes Anti Malware to give it a cleanup. It's a free download. Google for a link.
    Main Surround -
  • GaryZ06
    GaryZ06 Posts: 317
    edited June 2009
    I deleted history and the cache and it still does the same thing.
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • GaryZ06
    GaryZ06 Posts: 317
    edited June 2009
    nguyendot wrote: »
    It says it not for Mac
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2009
    Is the website www.z06vette.com?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • GaryZ06
    GaryZ06 Posts: 317
    edited June 2009
    appadv wrote: »
    No not that one....it's this one www.diecastxchange.com
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • John30_30
    John30_30 Posts: 1,024
    edited June 2009
    nguyendot wrote: »
    Mac's rarely get that. Like someone said, if you're running Safari, try it with Firefox- or the other way round. Also, clear your cache.
  • nguyendot
    edited July 2009
    John30_30 wrote: »
    My apologies, I missed the part where he said he had a Macbook :cool:
    Main Surround -
  • GaryZ06
    GaryZ06 Posts: 317
    edited July 2009
    nguyendot wrote: »
    Yes a Macbook but the weird part is it ONLY happens when I try to go to the one website....every other site is fine.....It' not the site cause everyone who tries it can get on....jeez I'm confused as usual.
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • bobman1235
    bobman1235 Posts: 10,822
    edited July 2009
    It really sounds like a cookie or cache problem, did you try clearing cookies?
  • GaryZ06
    GaryZ06 Posts: 317
    edited July 2009
    bobman1235 wrote: »
    Yes...cookies,cache and history.
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • bobman1235
    edited July 2009
    Did you try another browser as suggested? It's possible someone hijacked your router. Did you try it on your computer but from a different internet connection? Have others tried it using YOUR internet connection but their own computer?
  • GaryZ06
    GaryZ06 Posts: 317
    edited July 2009
    bobman1235 wrote: »
    If they hijacked it why is it only doing this on 1 site only and not others?.I have not tried it with someone else's computer on my connection.
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • bobman1235
    edited July 2009
    Router redirects can behave in strange ways.
    Here's one way to test it : assumign you're using a router, right now your internet connection goes from a modem to the router. Disconnect that wire from the router, and plug it directly into your computer, so it's just a straight ethernet connection from MODEM to your laptop. Then try the site. If it works, then your router is compromised, and you should reset it to its factory settings.
  • GaryZ06
    GaryZ06 Posts: 317
    edited July 2009
    Update: I called Apple and after checking a lot of stuff they said it is a DNS Changer Trojan.Now I have to find a software program that will get rid of it.
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • KrazyMofo24
    edited July 2009
    To prove that try to ping 70.85.181.74
    Setup:
  • GaryZ06
    GaryZ06 Posts: 317
    edited July 2009
    How do I do that? Remember I'm using a Mac.
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • KrazyMofo24
    edited July 2009
    Type that ip address in your address bar in see if it pulls up a page. This is the ip address of that page.
    Setup:
  • GaryZ06
    GaryZ06 Posts: 317
    edited July 2009
    This is what it pulls up...Great Success !
    Apache is working on your cPanel® and WHM™ Server
    If you can see this page, then the people who manage this server have installed cPanel and WebHost Manager (WHM) which use the Apache Web server software and the Apache Interface to OpenSSL (mod_ssl) successfully. They now have to add content to this directory and replace this placeholder page, or else point the server at their real content.
    ATTENTION!
    If you are seeing this page instead of the site you expected, please contact the administrator of the site involved. (Try sending an email to <webmaster@domain>.) Although this site is running cPanel, WebHost Manager, and Apache software it almost certainly has no other connection to cPanel Inc. or the Apache Group. Please do not send mail about this site or its contents to cPanel Inc. or the Apache Group.
    About cPanel:
    cPanel is a leading provider of software for the webhosting industry. If you would like to learn more about cPanel please visit our website at www.cpanel.net. Please be advised that cPanel Inc. is not a web hosting company, and as such has no control over content found elsewhere on this site.
    About Apache HTTP Server:
    The Apache HTTP Server is an open source web server which powers many of the worlds web sites. The Apache HTTP server is part of the Apache Group's many influential projects. Their efforts have helped shape much the world wide web, and they continue to be a dominating force in the web hosting industry.
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • KrazyMofo24
    edited July 2009
    That's what I got to so it does appear it's a DNS issue. I'm not sure why it didn't pull up the actual page. Most websites will do that when you put in the ip address.
    I'll try to do some research on that trojan.
    Setup:
  • KrazyMofo24
    edited July 2009
    Here you go http://www.securemac.com/dnschanger-bulletin.php
    Hopefully that will work.
    Setup:
  • GaryZ06
    GaryZ06 Posts: 317
    edited July 2009
    I tried those two DNC Changer Tool and MacScan and they they found nothing.I am thinking since they're the free versions they are not that good and the pay versions are better.....Oh thanks so much for helping me
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • Sami
    Sami Posts: 4,634
    edited July 2009
    GaryZ06 wrote: »
    With ping of course... :)
    Open terminal, type in the following command:
    ping 70.85.181.74
    You should get something like this in return:
    sami@keminmaa:~$ ping 70.85.181.74
    PING 70.85.181.74 (70.85.181.74) 56(84) bytes of data.
    64 bytes from 70.85.181.74: icmp_seq=1 ttl=50 time=23.2 ms
    64 bytes from 70.85.181.74: icmp_seq=2 ttl=50 time=22.9 ms
    64 bytes from 70.85.181.74: icmp_seq=3 ttl=50 time=23.1 ms
    64 bytes from 70.85.181.74: icmp_seq=4 ttl=50 time=27.4 ms
    Then do the same with the address:
    ping diecastxchange.com
    sami@keminmaa:~$ ping diecastxchange.com
    PING diecastxchange.com (70.85.181.74) 56(84) bytes of data.
    64 bytes from 4a.b5.5546.static.theplanet.com (70.85.181.74): icmp_seq=1 ttl=50 time=23.5 ms
    64 bytes from 4a.b5.5546.static.theplanet.com (70.85.181.74): icmp_seq=2 ttl=50 time=23.2 ms
    64 bytes from 4a.b5.5546.static.theplanet.com (70.85.181.74): icmp_seq=3 ttl=50 time=24.0 ms
    64 bytes from 4a.b5.5546.static.theplanet.com (70.85.181.74): icmp_seq=4 ttl=50 time=23.0 ms
    Nmap shows http port to be open, but I don't get the website to come up either.
    sami@keminmaa:~$ nmap -PN 70.85.181.74
    Starting Nmap 4.76 ( http://nmap.org ) at 2009-07-01 19:17 CDT
    Interesting ports on 4a.b5.5546.static.theplanet.com (70.85.181.74):
    Not shown: 941 closed ports, 45 filtered ports
    PORT     STATE SERVICE
    1/tcp    open  tcpmux
    21/tcp   open  ftp
    22/tcp   open  ssh
    53/tcp   open  domain
    80/tcp   open  http
    110/tcp  open  pop3
    111/tcp  open  rpcbind
    143/tcp  open  imap
    443/tcp  open  https
    465/tcp  open  smtps
    993/tcp  open  imaps
    995/tcp  open  pop3s
    1040/tcp open  netsaint
    3306/tcp open  mysql
  • VSchneider
    VSchneider Posts: 443
    edited July 2009
    It seems the www.diecastxchange.com site is having some issues.
    Try Googling for "diecastxchange.com"; the "Diecast Forums" and a number of the site's sections come up, such as:
    - Diecast Forums Home
    - DX "For Sale" Diecast Classifieds
    - Kyosho
    - AUTOart Diecast Cars DX Diecast Want Ads
    - Minichamps Paul's Model Art
    - CMC
    - fUT Models
    I can also see some Google-cached pages, but the links themselves do not open directly.
