Rm8 Center Channel
Lsi9
Lsi9 Posts: 616
edited June 2009 in Speakers
Hey Guys
I am planning on building a modest yet powerful HT built around my 2 channel system, currently looking at a UMC 1 & XPA5 to add to it.
I need a CC since I have RM 3000 surrounds I thought it might be cool to have an RM8 CC. Whats a better alternative?
Thx
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP
Post edited by Lsi9 on
  • Lsi9
    Lsi9 Posts: 616
    edited June 2009
    bump
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • apphd
    apphd Posts: 1,514
    edited June 2009
    Sounds like what could be a real nice set-up that IMHO the RM8CC would fall short for the front stage when used with the Audio Physic. You should be looking for something that will compliment them both with timbre and output. No idea how the timbre would be until you try. But output I think would be too week from the RM8 verses the Scorpio's.
    The match between the CC and the surrounds is far less of importance than the match with the LCR front stage.
    I would look more at the CSi A6 or LSiC from Polk or try and find the Audio Physic Celsius center.
