Need Help Powering my Monitor 70s
edited December 2009 in Speakers
I use my monitor 70s along side cs 2 center channel and two old onkyo surround speakers, to watch alot of blu-ray movies and listing to music. I have already blow my tweeters twice on the monitor 70 speakers while listing to music at high volumes, no distoration they just stop working.I currently have a ht560 onkyo hometheather reciver, which puts out roughly 85 watts per channel. I want to know is lack of power causing the tweeters to blow, and if yes what kind of home theather reciver can i get to power these puppies so i can crank them up without worries, i really want to stay in $600 range
Post edited by Djbuddy on
Welcome!
    edited June 2009
    Djbuddy wrote: »
    I don't know what you consider loud but you may be clipping the amp in the avr, that will blow tweeters if that's the case. Right now I'm running my M70 off a single Emotiva BPA-1 but I also have them crossed over at 80hz to my subs so the load wasn't as difficult. If you are running the monitor 70 full range and have a sub available you might want to try intergrating the sub with the speakers to take some of the load off them, thus requiring less power from the AVR.
    I'm assuming your AVR is one from a HTIB setup? You may want to look at the Adcom GFA-555(II) on ebay and pair it with a pre of your choice. You can pick up the amp for under $300 regularly and another AVR with pre-outs is not hard to find in the $300 range either.
    edited June 2009
    Those Onk HTIB receivers are based on the 5xx platform, not bad, but certainly the specs are suspect. Matt's pointed you in the right direction. If you're blowing tweeters, it's probably due to clipping the AVR at extremely loud levels. Turn it down or get a more capable AVR, then still keep it reasonable. You need lots of clean power for loud playback without risk of damage to speakers (not to mention ears).
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
    edited June 2009
    Im not a pro in the home audio area, but what is clipping dont want to sound like a newb but i just never heard of that term. Can it also be a user set up error causing the tweeters to blow, i use the mic that came with the reciver to set up all the levels and crossovers for the htib.
    edited June 2009
    Djbuddy wrote: »
    http://en.wikipedia.org/wiki/Clipping_(audio)
    edited June 2009
    Can you tell if its clipping by how the speakers sound?
    HOME AUDIO:
    Electronics:
    HK 354
    Front Power: CARVER TFM-35
    Center Power: Audiosource Amp One
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    psw 125 + psw 505 = BOOM
    CAR AUDIO
    Infinity 6032CF's all around
    edited June 2009
    like the sound of the tweeters....would it be very bright sounding?
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    edited June 2009
    Some distortion right before nothing.
    edited June 2009
    Yes....it's called 'distortion'.
    Monitor 70s are notorious for clipping on weak amps and popping their tweeters. I've run mine off a Denon 2807 which is a 31 lbs, 110 watt/channel unit. Never had any problems, I added an Adcom GFA-555 into the mix and they'll play as loud as you want with no problems. If you want to play unreasonably loud...get good external amplification!
    Also, I've found with the M70s you shouldn't PUSH them too hard during the break-in period. A lot of people pop their tweeters during that time!
    cnh
    edited June 2009
    royalty wrote: »
    The sound becomes compressed, like your missed notes because the amp cannot supply enough power at high volumes. It should be fairly easy to detect.
    edited June 2009
    I currently have the monitor 70's and they sound great with my Onkyo TX-SR606. You can typically find good deals on this receiver...Well worth the money.
    My Home Theater:
    Display: 61" RCA HD DLP
    A/V Receiver: Onkyo TX-SR606
    Fronts: Polk Audio Monitor 60s
    Center: Polk Audio CS2
    Rears: Yamaha YHT-790s--The Tower Ones
    Sub: Polk Audio PSW125
    Blu-Ray Player: Samsung BDP-1500
    Gaming Systems: Xbox 360 w/HD DVD player & Nintendo Wii
    Satellite: DirecTV HD DVR
    The Bed Room:
    Display: Vizio 32" HD LCD
    Blu-ray Player: Samsung BDP-1000
    Audio: Yamaha HTib
    Gaming Systems: Sony PS2 and Nintendo Gamecube
    edited October 2009
    Hi. This is my first post in the Polk forums. Hello to everyone.
    I am deeply considering getting the Monitor 70s.
    Would bi-amping help give the Monitor 70s more headroom? I have a Denon AVR-890 and I have the option to bi amp. Given that it runs normally at 105 watts per channel...does that mean that if I bi-amp those Monitor 70s they will be getting 210 watts a piece? Just wondering if that is how the math works and if that would make any noticeable difference.
    edited October 2009
    edited October 2009
    xcapri79 wrote: »
    Does this help?
    Absolutely. Thanks. They will start as two channel and then it will eventually be 5.1. I will add speakers as I get money. :)
    I snuck downstairs a few times already and listened to some classical albums at night on these old Sony's I have and the receiver has even made them (sonys) sound better. So I cannot wait to get some better speakers for it. After reading some of the posts about the Monitors being good for music that has pushed me more towards them too. My friend has some Monitor 70s so I am going to bother him and let me go listen. Thanks again for the quick reply! :)
    Just a quick update on an ancient post...I got the monitor 70s and I bi amped them and they sound great! Thanks!
    Glad you like those...they are a nice sounding speaker and a good Denon will bring out a lot of that, if you add a power amp into the mix....they sound even better..
    Stick around and post a bit more if you'd like to....lots to learn/share?
    cnh
    +1 cnh, I love my 70's!!
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
Welcome!
Welcome!
