T8L 250V fuse?
Tomasito
No sound was coming out of the left channel of my Rotel RB-1080. Called up Rotel, the technical CS advise me to open it up and check the fuse of the left channel. He was right the fuse blew, but when I check the fuse, it did not have any amp rating written on it. the only thing written on it was "T8L 250V" .
I went to Radioshack but they couldn't help me because they weren't familiar with the fuse rating.
Can anybody advise me the equivalent fuse amp rating for a T8L 250V fuse?
Post edited by Tomasito on
Hi Mr. Tomasito,
I am facing exactly the same issue like you did. So did you solve the problem? how about the amp of the fuse.
Any advise?
Tks. -
Hello,
In all likelihood it is an 8 ampere fuse and since it is an output protection fuse I would imagine it is a fast-blow type. But, you should definitely check with Rotel before using a replacement. There may be another descriptive number found on the other metal cap of the fuse, "160" for example which would provide a series identification. But it would be best to check with Rotel.
Regards, Ken -
Necrothread... Working on one amp... has two fuses - one clearly marked 6.3A 250V, the other one on the output is marked as T8L 250V. Same fuse on all each of 7 channels, no idea what it is.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Just to add, for those who care. T8 fuses are are "T" - time delayed (i.e. slow-blow), 8 is 8-amps, don't know what L stands for. Usually 8-amp slow-blow are marked T8A.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
