xlr/rca combo
organ
organ Posts: 4,969
edited June 2009 in 2 Channel Audio
My pre has no xlr in but does have xlr outs. Also my amps have both rca and xlr in.
I'm currently using rca all around. Would be an improvement if I go... source/rca/pre/xlr/amps?
Post edited by organ on
  • BlueFox
    BlueFox Posts: 15,250
    edited June 2009
    Whether there will be an improvement or not I suspect only you can tell by doing an A/B test.
    I do know that my 2 channel system is completely XLR except for a digital SPDIF, is dead silent, and sounds great. However, I AM NOT going to try RCA ICs to find out if it gets better or worse. :)
  • ben62670
    ben62670 Posts: 15,969
    edited June 2009
    Is your pre and amp true balanced?
    Ben
    heiney9 Posts: 25,492
    edited June 2009
    Try it both ways. I have the capability to go balanced (xlr) from source to pre to amp but I prefer single ended RCA connections.
  • Systems
    Systems Posts: 14,872
    edited June 2009
    BlueFox wrote: »
    +1.
    If the pre and amp were far apart and required a long cable run then the extra immunity to noise provided by the XLR's might be benificial.
    Testing
    Testing
    Testing
  • organ
    organ Posts: 4,969
    edited June 2009
    I think I will try out a pair of xlr. I have no idea if the equipments are true balanced.
    I don't have any noise issues with IC's. I"m using 1.5m IC's.
