RM20 or RM85
I am currently trying to decide on a 5.1 speaker system. F.S. currently have the RM20's on for 399.99 but no sub. They also have the RM85FS $999.99 which is the RM85's with a PSW125 Sub. I figure if I buy the RM20's at $399.99 and pick up a subwoofer for $250 I would be ahead of the game but which speakers are better the RM20's or RM85's?
Post edited by rsmiley on
1. Aluminium cabinet versus cheap composite / plastic cabinet...
2. Larger drivers and tweeters...
3. Slightly better Frequency response...
4. Slightly better power handling...
5. With the $600 left you can do better as far as the subwoofer IE: if you acquire the PSW404, means more bass power and lower bass frequency response ad there would probably be some money left from the $1K the RM85 would cost you!!!
The RM20 5pack is therefore a much, much, much better deal!!! However, I would suggest you have a listen!!!DARE TO SOAR:
Your attitude, almost always determine your altitude in life -
Rm20s also have the five way binding posts. Pretty sure the RM85s don't (Just the cheapy push clips). I have the RM6880 (basically an RM10 set, with a little 60 watt sub). I love these things. I've since upgraded to an all RTi setup, but I refuse to sell my RM6880 because I think they're an amazingly good quality speaker.
My buddy also has the RM20 set with an MTX sub. He swears by the RM series. -
I've pretty much decided on the RM20. I was looking at the specs compared to the RM85 last night and I think the RM20's are a better choice. You're right the 5 way binding posts are better than the spring clips. Now I just have to decide on a sub to go with the set.
JohnLocke88 wrote: »Rm20s also have the five way binding posts. Pretty sure the RM85s don't (Just the cheapy push clips). I have the RM6880 (basically an RM10 set, with a little 60 watt sub). I love these things. I've since upgraded to an all RTi setup, but I refuse to sell my RM6880 because I think they're an amazingly good quality speaker.
Cheers!
TKDARE TO SOAR:
I own both the rm95's as well as the rm20's. I would put the rm 20's over the rm 95 95% of the time, and can only assume that the same would go for the 85's. I am selling a set on here of the rm20's if you would like. Brand new, black. Good luck with your speaker exploits either way!Bulls make money.
Bears make money.
Pigs get slaughtered.
You, my friend, are the bacon. -
http://www.polkaudio.com/forums/showthread.php?t=84607
I guess he could use the sub also. Good luck to both of you, I hope you can both make a great deal.DARE TO SOAR:
Thanks technokid...probably should have thought of that...
Yea let me know if your interested, let me know your budget, I am sure we can make something work. I have been dying to get rid of these, so much to the point where I have cut 2-400 off the prices already.
--MarkI was just coming back to show him your thread:
I guess he could use the sub also. Good luck to both of you, I hope you can both make a great deal.Bulls make money.
Bears make money.
