Adcom GFA-6000 vs. Carver AV-505
Paden501
Does anybody have experience with these two amps? A local dealer has each of them for <$300 and I'm trying to decide which one to go with.
Thanks in advance,
Thanks in advance,
~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9
My System
CD: Jolida JD100a
TV: Sony 52" XBR9
Post edited by Paden501 on
Anybody?~Matt
My System
CD: Jolida JD100a
TV: Sony 52" XBR9 -
I think they are both good amps. I would go with the Carver but I am Carver bias.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
I just saw that you are in Pittsburgh. You looking at the dealer in Ross TWP called Vintage HIFI? www.vintagehifishop.com
I have bought some stuff off of him in the past. Good guy to deal with. You will not be unhappy dealing with him.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
Yeah I bought my reciever off of him not too long ago. He's got some good stuff there, including the SRS's that everybody's been posting about lately.~Matt
My System
CD: Jolida JD100a
TV: Sony 52" XBR9 -
Thanks in advance,
I am using the AV-705 and love it. Not familiar with 505 but would assume the basic architecture is the same with less power (80 vs 125 ??). I do like the Power Steering feature that gives you half again the power to any channel that needs it. Nice touch.
I've owned Adcom amps in the past but not a 6000 so maybe someone else could jump in on that. I'm not a real fan of amps with different power for different channel. I believe the Adcom is 3 X 100 plus 2 X 60 but that's just a quick of mine. I'm sure in the real world it's not a big deal.
Sorry I can't be more help.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
Thanks Marty,
I do wish he had a 705 available because I've read good things about that. I'm hoping that the 505 is indeed from the same mold. I can't find any spec on it that tells me whether or not it'll handle 4ohm loads though. My Monitor5's are 4ohm so I'm a little concerned about that.
We'll see what happens.~Matt
My System
CD: Jolida JD100a
TV: Sony 52" XBR9
