3 Momo Repost. Help me out Kim
AcuraLegend
Correct me if i'm wrong, but I thought it would be necessary to make a smaller box if you invert the speaker due to there being more space inside the box where the driver would have been? Also, with personal experience, it seemed like my subs performed better when they shared the same airspace. Cause I went from a chamber box to a shared box when I had my db12's and they seemed to hit harder. I'm not really too worried about box resonance cause its going to conservatively sized box and I'm using doulbe refined 1" MDF Board. Also I thought it was only necessary to stuff your box if you build your box smaller than the recommended size. But if I were to do so, what effect would it have on the sound? Thanks.
Allerick B.
I'm sorry if i'm bothering you, I'd just like to have my info right before I start on my box. Thanks
Allerick B.
93 Black Acura Legend 6-spd Manual. Soon to be Pioneer Deh-9300 Head Unit Deq-9200 Equalizer and DSP, Streetwire interconnects. PPI PC4400 Chrome(50x4 rms) and PPI PC2400 Chrome (100x2 rms or 400x1) MOMO 6.5" Component Highs up from, Infinity Kappa 6x9's in the rear
Post edited by AcuraLegend on
