Good deal for this sub?
strife1013
I have a sub coming in the mail a Polk Audio 12" 505 (in sig) and ran across this CL ad. Should I keep my new sub which comes in tom... or should I get this one?
http://cosprings.craigslist.org/ele/1233320047.html
Home Theater:
Receiver- Yamaha RX-V867
Front- Polk Audio Monitor 70
Center- Polk Audio CS2
Surround- Polk Audio Monitor 70
Back- Polk Audio Monitor 60
Sub- Polk Audio PSW505 12-Inch Powered Subwoofer
T.V.- 56" Samsung DLP 1080P
Blu-Ray- 60 GB PS3 & Sony BDP S570
Post edited by strife1013 on
get both.......Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
I doubt my AVR will support 2 subs.Home Theater:
Blu-Ray- 60 GB PS3 & Sony BDP S570 -
They're both powered, the AVR doesn't have to. Just run a Y-cable.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Sure it will, just use a "Y" cable....I have the Pio-816 and I run 2 PSW10 subs, sounds great with my set-up. If you decide to try it, I have a "Y" cable Ill send you, no charge. just let me know.:)Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
So should I run 2 subs? What's the benefits of that besides too much bass (maybe too much) you don't think that PSW505 will be enough on it's own?Home Theater:
well, first let me say 2 subs isnt too much with my system, granted each of my subs are only 50 watts each but I get a nice even bass tone during movies throughout the room. I guess depending on your room size 2 subs of that caliber may or may not be overkill. For example: The movie U571 where depth charges are being dropped, I get some pretty decent response from my subs where as with only 1 PSW10 I would be wanting more. I personally dont think it would be too much. Ya never know, you might love it..Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I'll keep that in mind, right now I'm kinda looking to add an amp, I heard my AVR doesn't support it, not sure which components I would need and not sure as too where or what kind of amp to get for my system.Home Theater:
strife1013 wrote: »So should I run 2 subs? What's the benefits of that besides too much bass (maybe too much) you don't think that PSW505 will be enough on it's own?
You can always tune out some bass. It's more of a response/fullness thing for me. I run dual Omni S8s in my HT setup. One was fine. Two was better.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thats strange that your AVR doesnt have pre-outs
, my 816 does.
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
It might, I would have to look, what do they look like?Home Theater:
strife1013 wrote: »It might, I would have to look, what do they look like?
Bottom, middle of the receiver in the multi-channel group one RCA jack labled "subwoofer". In some receivers it's in the pre-out section.
I would stick with the Polk and get a second one of the same model later on. It's difficult to get two different subs with different frequency responses to work well together. -
No such thing as too much base.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
This is so i could hook up an amp?Home Theater:
strife1013 wrote: »This is so i could hook up an amp?
Here's a receiver with the pre-outs identified. They would be where you plugged in RCA cables connected to an external amplifier (one or more). Typically in a 7.1 channel receiver there would be 7 pre-out plus a subwoofer output. SOme receivers have multi-channel inputs (for things like Bluray players), some receivers have pre-out jacks for external amplifiers, and some have both.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
nope....I dont think your model has pre-outs.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I should have the sub hooked up to where it says subwoofer pre-out?Home Theater:
deleted....misinterpreted someones response.Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
strife1013 wrote: »I should have the sub hooked up to where it says subwoofer pre-out?
yessir!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Thanks they where I have had it hooked up too. So if I had a Y cable I would hook up both subs to it?Home Theater:
that is correct.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Well I get my 12" PSW 505 today and will hook it up and see how well it does on it's own, from the specs on it it should blow away my Sony one I have right now. I can't wait! I think I will upgrade my AVR sometime soon, as I don't get HDMI audio and from the looks of it I can't hook up an external amp to it, any suggestions on a new AVR and amp?Home Theater:
strife1013 wrote: »Well I get my 12" PSW 505 today and will hook it up and see how well it does on it's own, from the specs on it it should blow away my Sony one I have right now. I can't wait! I think I will upgrade my AVR sometime soon, as I don't get HDMI audio and from the looks of it I can't hook up an external amp to it, any suggestions on a new AVR and amp?DARE TO SOAR:
Your attitude, almost always determine your altitude in life -
Techokid
Wouldn't hooking up an external amp add more cleaner power to my speakers, i.e. better sound? Or am I just kinda throwing money out the door with that?
As for the sub, just got it connected and it sounds really good for far. Just played a few Eminem songs and a trailer haven't gotten to movies or anything where things blow up will do that with Generation Kill tonight.
I do know that if I'm gonna add another sub it would be the same kind; as Polk Audio has from what I read good warranties, 5 year ya and apart from that it matches my set up real well, silver and black and sounds great. Also finding it at 250 isn't bad either, don't know if it's gonna stay at that price or what.....
Also quick question about settings for my sub, for phase should I have it at 0 or 180 degrees? And for the low pass should be at 60,90 or 120 Hz?? Not sure what those 2 settings do.Home Theater:
I think what Techno is trying to say is, with your current speakers (which are good speakers) you really don't need external amplification. You have a nice receiver there, unless you plan on upgrading your speakers I would just keep it. As for the phase setting it assures your sub is in phase with the rest of your speakers, play something with a lot of bass and try both settings, youll know which setting is correct by listening to the bass. I think my subs are set at around 80, i believe thats a good starting point.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
strife1013 wrote: »Well I get my 12" PSW 505 today and will hook it up and see how well it does on it's own, from the specs on it it should blow away my Sony one I have right now. I can't wait! I think I will upgrade my AVR sometime soon, as I don't get HDMI audio and from the looks of it I can't hook up an external amp to it, any suggestions on a new AVR and amp?Knucklehead wrote: »I think what Techno is trying to say is, with your current speakers (which are good speakers) you really don't need external amplification. You have a nice receiver there, unless you plan on upgrading your speakers I would just keep it. As for the phase setting it assures your sub is in phase with the rest of your speakers, play something with a lot of bass and try both settings, youll know which setting is correct by listening to the bass. I think my subs are set at around 80, i believe thats a good starting point.
Cheers!
TKDARE TO SOAR:
thank you for the info. I guess when I do upgrade the AVR it will be when HDMI 1.4 comes out, I guess I won't replace it for a few years as it's still under warranty at Best Buy. As for the speakers those are my upgrade, I just bought all of these new speakers this month so yeah, not getting new ones for quite awhile. They are way better than the sony bookshelf speakers I had.Home Theater:
you can never have two many subs
+1 bassfann
I'm running 4 actually and explosions, cars crashing, everything just comes alive in movies like Ironman, Godzilla, Transformers and more. You can never have too many subs, for HT ideally you should have 4 for even tone throughout the room.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
I can't really disagree except that I would always feel like my HT room were just a big-a$$ed car stereo system rolling past my house--with its trunk full of 12" woofers and 1000s and 1000s of watts of power--here I come BOOM. BOOM..BOOM...I'd be waiting for me to pass by and I wouldn't. Of course I'm just yanking your chain...K...
That's just not for me.Currently orbiting Bowie's Blackstar.!
Haha it's cool. It'd be one thing to set all the subwoofers up loud, listening to "rap" and trying to get the cops called on me, but it's something else when you calibrate your subs to blend in seamlessly with your system and have perfect response throughout your room. Also love the width setting on my avr for my center channel, makes my "sweet spot" larger than it normally would be.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
