Are these maggies a good deal?
dane_peterson
dane_peterson Posts: 1,903
edited June 2009 in Speakers
I'm craigslisting while out of town and found these. Good deal?
http://stlouis.craigslist.org/ele/1231918285.html
Post edited by dane_peterson on
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2009
    Yes.
    I just saw a pair go for $100 in LA, Ca. That was unrealistic. These generally go for 350 or so.
    Main Surround -
  • Ricardo
    Ricardo Posts: 10,636
    edited June 2009
    Yes; that is a good deal. The problem with old maggies is that the glue they used in the panels aged, and then there can be delamination.
    http://www.indiespinzone.com/mag/mag6.html
    SOPA
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2009
    I wouldn't buy them.
  • StephenEC
    StephenEC Posts: 57
    edited June 2009
    dane_peterson ,
    I would not pay that much for them . More than likely , these spwakers are de-laminating , or the tweeter wire is corroded . . . this a common problem with Maggies this old .
    If you could talk the seller down to lets say , a $100.00 , then I would say , You have a deal , but not $200.00 . . . as they (the maggies ) will need money thrown at them to make them sing .
    Plus , You better have a High Current amp to Drive them .
    Hope this Helps , Stephen
    nooshinjohn Posts: 25,932
    edited June 2009
    I would just get them. It is a great speaker. I used to build the Maggies at the factory in Maplewood back in the 80's. I know they still support them and if you need their assitance they can always go to them. seeing as you are local the cost will be much less as shipping would not be a factor. Of course negotiate a better price!
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2009
    Dane,
    I own MG-II, which are a few models up in terms of age (MG-I, Ib, Ic, then mine).
    Regarding physical condition. At this age, the tweeter wires are gone, whether previous owner used these speakers or not (late 60s, early 70s manufacturing date). You will need to get the rewire kit from Magnepan (very helpful staff, $50 kit, plus you buy your own 3M glue).
    I paid less for mine than the price listed in this CL ad (known that the tweeters were gone). Rewired the tweeters, changed crossover capacitors (put Solen polypropylene caps), refinished frames and made new socks (black grill cloth material).
    I was not able to drive these speakers with Carver TFM-24 (350W/ch into 4 Ohm beast). I was still at low level, but the volume was up and there was no dimension, seemed that Carver needed more push to linearize, but I was afraid to blow the panels.
    I switched to Dynaco ST-70 (35W/ch) tubes, and the difference is amazing. The bass is clean (yes, with panels), the mids and voices are super nice. You won't get very crisp highs with these panels, but Maggies will give you the most natural sound and amazing wide and deep sound stage. (I do like the highs that I get from CDs, very smooth and clean, but with "cone" speakers highs would definitely sound sharper).
    Like I said, I drive them with Dynaco ST-70, use Carver C-1 preamp, Cambridge Audio 640P phono pre, Dual 1228 TT, Toshiba HD-A20 CD. I really love these speakers. Eventually, I did add restored Velodyne ULD-15 for deeper bass, but that's for my taste.
    Mine looked exactly like the ones in CL ad when I got them. I hated the frame and grill colors.
    Now they look like this:
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • Ender
    Ender Posts: 603
    edited June 2009
    Wow. I like that look. It's sexy. Good job on the refurbishing job.
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • dane_peterson
    edited June 2009
    Great work on your Maggies. I elected not to go with these... Heading back home right now. It would have been a tight fit in the G6 in any case.
    Thanks everyone for the input. Someday I hope to try planars!
  • dane_peterson
    edited June 2009
    I never heard from the seller. I did email him... Just no response. Had he messaged me back, I would have gone to take a look regardless, for the reasons you mention.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited June 2009
    "I used to build the Maggies at the factory in Maplewood back in the 80's"
    Was that in Maplewood Missouri?
    I'm gonna check out the speakers F/S and post more info.
    SDA SRS 2.3TL's
    SDA 2B TL's
    edited June 2009
    no... Maplewood Minnesota.
