I need some big inductors
ben62670
Tittle says it all. I am looking for 5.6-16mh inductors.
Ben
Ben
Post edited by ben62670 on
http://www.alphacoredirect.com/index.html?lmd=39634.474294
http://www.northcreekmusic.com/COILS.html
How about what gauge, air core/iron core, etc..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I'll call you you ****!
Seriously I need high DCR Polk Style inductors.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I knew that value sounded familiar....before I went to active crossovers for my subwoofers, I used to make my own passive sub crossovers. I looked in my components box and I still have 3 very nice German made Intertechnik inductors in 5.6mH value.
You want them you can have them....PM me.....
Their company description cracks me up....
Since 1973 Intertechnik is a well-known manufacturer of first-class electronic components, coils, drivers, and capacitors in Germany, the heart ofEurope.
Located in Kerpen, the community of the formula one champion Michael Schumacher, Intertechnik has grown substantially to the leader of selling and distributing electronic products "
Here is the inductors description....
HIGH QUALITY FERRITE CORE INDUCTORS The design of this coil type is similar to the air core coil, except that it contains a soft, special high quality ferrite core. The magnetisation curve is linear at small to medium volumes. This coil type is suitable to confined conditions where large air core coil won't have enough space. Specifications: Conductor: 99.99% Oxygen-free Copper Insulation: Type V Enamel Bobbin material: ABS Dimensional stability (Shape retention): 85oC Inductance values tested at: 1 kHz/25oC Inductance tolerance: +/-5% Connecting leads: 10/40/50mm long (tinned: 9/35/45mm) Core type: Bobbin style Core material: HQ soft ferrite (for very good power transference) Inductors HQ43/45 & 58/56 can be mounted upright or on their side. Table headings: HQ 40/30 * 0.95-1.12mm conductor diameter Part No. //LmH//R Ohm//conductor diameter//Type HQ 43/45 * 0.85mm-0.95mm conductor diameter Part No.//LmH//R Ohm//conductor diameter HQ 58/46 * 1.12mm-1.60mm conductor diameter Part No. LH//R Ohm//conductor diameter Diagram headings: Dimensions in mm
http://www.intertechnik.com/Lautsprecher-Shop/Cross-over-electronic-parts/Inductors/HQ-Ferrite-Core-bobbin-style/1768,en,68.html
The specs on mine are as follows.....
L = 5.6mH
R = 0.36 ohms
Conductor diameter = 1.18mm
This is just a generic picture of their 2.2mH inductor....couldnt find the 5.6mH on their website.
The first rule of Fight Club is you don't talk about Fight Club -
You could always make your own."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
http://www.parts-express.com/erse-18-gauge-air-core-inductors.cfm
http://www.parts-express.com/erse-16-gauge-inductors.cfm
http://www.parts-express.com/14-gauge-c-core-toroidal-inductors.cfm'65 427 Shelby Cobra
'72 Triumph TR-6
__________________
'88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
'86 Polk SDA CRS+
'84 Polk Monitor 10A (Peerless tweeters)
'05 HSU VTF-3 Sub (Original OEM)
'20 HSU VTF-3 Sub (three more, 100% cloned)
'93 Carver TFM-35
'88 Carver M-1.0t
'88 Adcom GFT-555
'88 Adcom GFP-555
'88 Adcom GFA-555 (upgraded/restored)
'88 Adcom GFA-555 (a second one upgraded/restored)
'05 Onkyo DV-555 media
'89 Fosgate 360 Digital Space Matrix
'89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
'91 Kenwood Basic M1D Amp
'89 Pioneer Laser Disc media
'89 Sony SuperBeta HiFi media
One PGA2310 based custom built remote volume control
Four Polk T-15's
Four Polk TSi-200's
Four Polk TSi-100's
Two Polk CS-10's
