Using sub with SDA-SRS 2
Polkie2009
Polkie2009 Posts: 3,834
edited June 2009 in Speakers
Newbie hear to the site, I was wanting to get some opinions here from ya'll on this.Is it better to use the sub out cable to the sub or use speaker wire to the sub and then to the SDA-SRSs. I thought I had heard where Polk Audio suggested not using the sub out cable way?? I'm not using the interconnect cable between the Polks at this time since I'm using this setup for home theater DD,DTS,etc.All help is appreciated.
Post edited by Polkie2009 on
  • thuffman03
    thuffman03 Posts: 1,325
    edited June 2009
    I have run my subs both ways and for HT I like using the LFE output but for 2 channel listing I like to use the cross over's in the sub.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
