psw505 isthere a better sub for 275 shipped
slowpolky
slowpolky Posts: 714
edited June 2009 in Speakers
title says it all, i wana know if there's anything else out there that can top the 505 for 275 shipped, i am open to opinions but please dont tell me things like, for 100 dollars more ..etc...
Post edited by slowpolky on
  • Matt34
    Matt34 Posts: 318
    edited June 2009
    I don't know much about the PSW505, however I can recommend a couple other to research.
    Check out the Premier Acoustic PA-120, you can find it on ebay for $230 shipped. There is a massive thread about it on the AVSforums.
    http://cgi.ebay.com/H100-Premier-Acoustic--PA-120-Subwoofer!-Black-Color!_W0QQitemZ200327210359QQcmdZViewItem
    I would also consider the Cadence CSX-12:
    http://cgi.ebay.com/CADENCE-CSX-12--12%22--350-WATT-HOME-THEATER-SUBWOOFER_W0QQitemZ310148235365QQcmdZViewItem
    You can sometimes find an used SVS PB-10 for around $275 if you can wait.
  • RandyBox
    RandyBox Posts: 125
    edited June 2009
    slowpolky wrote: »
    Not IMHO...
    Love mine...:)
    Regards,
    Randy
  • slowpolky
    edited June 2009
    thats some good deals ,i'l get my learn on ,,,,,thank you very much for your input matt
  • concealer404
    concealer404 Posts: 7,440
    edited June 2009
    I will be up front and say that i haven't personally heard the PSW505.
    That being said, I have a Klipsch RW-10D that i am EXTREMELY happy with. It is definitely biased more towards HT than 2-channel, but it's not hard to listen to in 2-channel, either.
    Myself and MMadden25 have both had great experiences with this sub, unless he's updated since his last thoughts on it and i missed it.
    You may have to shop a little to get it in your price range, but i believe i paid $250 for mine, and i think he paid about the same.
    You WILL get some port noise until you get your placement worked out, as a warning ahead of time. Now that placement is right on mine, i haven't noticed anything at all. It's a sub that "disappears" very well. If i was blindfolded and listening to a movie, i coudn't tell you where the sub was located.
    The Mirage Omni S10 might be worth looking into. I believe if you're looking for a $275 sub, you should be able to find one. I also have two Mirage Omni S8s that i play with from time to time, i was using them in my HT setup before i tore it apart, and i love them.
    Like i said though, i'm not 100% positive on today's prices for these subs. I would imagine the PSW505 is more readily available at your $275 range, and from what i've heard, it seems to be a great sub.
  • slowpolky
    edited June 2009
    klipsch rw10 is a sub i will read reviews for , right now i'm reading alot of positives about the p a 120
  • concealer404
    edited June 2009
    slowpolky wrote: »
    Make sure it's not the RPW-10. I was not so impressed with that one.
    RW-10D. In my humble opinion, anything else in their newer lineup isn't really worth the money. :D
  • thuffman03
    thuffman03 Posts: 1,325
    edited June 2009
    I had a Definitive Technology Prosub 100 that I got for mid $200 shipped. I liked it a lot. I replaced it with a Sunfire but that is way out of your $$$ range.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • svtjoe
    svtjoe Posts: 55
    edited June 2009
    I had the Klipsch SUB12..($449)..I returned it and got on the Boston Acoustics HPS12HO deal they have. MSRP of $500 and I got it for $240 shipped.
    It is tigheter than the Klipsch 12 and from what I have read, it is supposed to be tighter than the 505 (I almost pulled the trigger on the 505, but went BA instead).
    Very very impressed with the BA HPS12!
    As stated, OMNI is supposed to be good. I was unable to demo a S10 and it was jacked up on price (Magnolia)
    Joe
  • slowpolky
    edited June 2009
    hey joe where did you get that boston from?
  • slowpolky
    edited June 2009
    from all the info here it seems like the omni is best but the best deal for 275 shipped goes to the boston
  • rdb2001
    rdb2001 Posts: 791
    edited June 2009
    slowpolky wrote: »
    PM Sent
  • slowpolky
    edited June 2009
    i just found a 15 inch sub ,acoustic audio hd sub15, it dips down to 20 hz , 500 w rms an 1000 max for 269 shipped
  • svtjoe
    svtjoe Posts: 55
    edited June 2009
    I looked into the 45 pages of the Acoustic Audio sub.
    I was going to get the SUb12, then I have read that the the Sub10 wasnt very good for music. I would imagine the 12 the and 15 being even worse.
    Loud, yes...but not sure how they cram all those watts with a cheap price. Some users reported getting the Sub12 for $150 shipped.
    PM was sent about the BA
  • concealer404
    edited June 2009
    svtjoe wrote: »
    Joe
    I demoed an Omni S10 Premier and i was flat out AMAZED at what it did. It was plenty to completely dominate a 15x20 room if you wanted to, but scaled back nicely and still had a great response for music. Couple with the fact that it looks GORGEOUS, i consider the sub to be a real winner. The Premier is out of the $275 price range. The best i found was a floor model for $320 about a year ago, and i'm still mad i didn't jump all over it. I consider it to be a better sub than the RW-10D i'm using now overall. The RW-10D is better for HT, the S10 Premier better for music, but neither are a slouch in any department.
    The difference between an S10 and an S10 premier isn't HUGE, and the S10 is still a great sub as far as i'm concerned. Like i said, i LOVE my S8s. Some of the most musical subs i've ever heard. You get almost no port noise no matter the placement, somehow. I'm still scratching my head trying to figure out how they did that.
    Anyways... here's a good deal on a factory reconditioned S10.
    http://www.customsoundco.com/Product_Detail.cfm?Product_ID=133&Special=1
    After further research, the RW-10D will be hard to find in your price range. You're looking at more like $400 for that, it seems. Sorry. :(
  • Conradicles
    Conradicles Posts: 6,143
    edited June 2009
    slowpolky wrote: »
    Can you provide a link? That one sounds interesting. Thanks.
  • strife1013
    strife1013 Posts: 61
    edited June 2009
    Where did you find it for $275 shipped? I bought mine at J&R, waiting on it to get here next week.
    Home Theater:
    Receiver- Yamaha RX-V867
    Front- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surround- Polk Audio Monitor 70
    Back- Polk Audio Monitor 60
    Sub- Polk Audio PSW505 12-Inch Powered Subwoofer
    T.V.- 56" Samsung DLP 1080P
    Blu-Ray- 60 GB PS3 & Sony BDP S570
  • concealer404
    edited June 2009
    The Acoustic Audio subs don't seem to be getting great reviews.... dodgy internals, cheap construction, nobody can seem to find them actually selling anywhere for retail price, etc....
  • slowpolky
    edited June 2009
    thats what ive been finding out about the sub15 . One guy wrote a review and said that he was sure there was even better 10inch subs that would sound better and he never noticed the diff in the specd 20hz from a cheap 10 inch he had that went down to like 30, it sounded worse Guys i dont know yet how to provide links for stuff yet, Idont even know how to post pictures of my setup. But the boston hps12 can be had at electonic expo for 240 with 30 shippin, the sub 12 can be had for the 269.99 shipped om ebay , i found all these stores on the google checkout after running a search
  • slowpolky
    edited June 2009
    sorry the hdsub15 is on ebay for 269
  • slowpolky
    edited June 2009
    i keep reading about the omni s10 , every time i do i hear that song ,,,,,,,The more i see you, the more i WANT you ,,
  • concealer404
    edited June 2009
    I'd consider ponying up the extra cash to grab an S10 from the link i posted above..... i'd say either that or the PSW505, to be honest. I didn't realize how much the RW-10Ds were going for, i apologize for wasting your time.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2009
    With subs, as with many things, you get what you pay for. For budget subs, it's best to stay with something that's a well known bang for the buck. Of those mentioned in this thread...the PA 120, Bic H100, Cadence CSX 12 and the 505 all are known quanities and safe buys. I've heard them all except the PA 120 which I think replaced the Bic. Though spec'd into the mid 20s, none of them can really get there without room gain, but each offers alot of slam and punch above 30hz.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • slowpolky
    edited June 2009
    the kilpsch rw10 can be had for like 360 so its not a waste of time reading into it , and ron i have read that the pa120 is supposed to be better than the bich100 lol the bic is also supposed to be better than the cadence
  • Ron Temple
    edited June 2009
    slowpolky wrote: »
    The old Bic was better than the old Cadence XSub, but the CSX 12 was greatly improved and I feel better than the H100. I've heard both Cadence subs (CSX 12 & 15). So the PA 120, may in fact be slightly better or close to the CSX 12, but there's not going to be a huge difference in these subs with similar box size, amps and drivers at that price point.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • concealer404
    edited June 2009
    slowpolky wrote: »
    Hrmmm.... $360 shipped? If that's the case, i'd personally look at that or the S10, then. You can get teh S10 for about $340 shipped from the link i gave you. If you're looking more HT, the RW-10D. More music, the S10, it's a bit faster of a sub and slightly more musical. It's also far easier to place.
    That extra $70-$80 going up from the Acoustic Audio Sub15 will make a HUGE difference going to either of these.
    Where are you located again? If you're within driving distance, i'd be more than happy to have you listen to either my RW-10D or S8s to get some impressions.
  • slowpolky
    edited June 2009
    i'm in MN , i should add that to my profile, i could buy sub driving a short distance in my gas guzler
  • concealer404
    edited June 2009
    slowpolky wrote: »
    Hrmmm... that'd be kindof far. I don't think i would sell any of mine, but if you're in the area for any reason let me know, and you're welcome to come take a listen. :)
  • Lib0rat0r
    Lib0rat0r Posts: 28
    edited June 2009
    Slowpolky, let me just start by saying I was in exactly the same situation as you about 2 months ago. I had about $250 to spend on a sub, and I wanted the best bang for my buck. I wanted a sub with the highest peak power and highest RMS wattage on the specifications size, but I also wanted it to come highly recommended from a large number of reputable home theater specialists and users.
    What I found most recommended, especially on the AVS forums, is the BIC Acoustech H-100 and the Premier Acoustic PA-120. I looked at both of them extensively, and narrowed it down to the PA-120, because it had better specifications and came at a lower price. The PA-120 also had great user reviews to support it, and in comparison to the H-100, there was little difference, and if any, in favor of the PA-120.
    So I finally decided on the PA-120 (I research for hours and hours)...and then it came time to find where to buy it. It is only available from a few places, with most people going to ebay for the $229 shipped. I ended it getting it from SoundDistributors (www.sounddistributors.com), where I used coupon code TV15 to get 15% off and had it for around $225 shipped. It arrived perfectly, and I have been a repeat customer at sounddistributors a number of times. Acoustic Sound Design also sells the subwoofer, as well as Polk Audio speakers and such. Acoustic Sound Design is an authorized Polk Audio internet retailer, and the brother of the guy in charge of that site works Sound Distributors...so I have gone to both of them for business. I am in no way affiliated with either site in any way, but if you are looking for a non-sketch, customer friendly, will-replace-instantly-anything-not-working, lowest cost place to go, it's there.
    Anyway, hope that helped.
    EDIT: I'm also from Minnesota by the way :)
  • Vdr1973
    Vdr1973 Posts: 72
    edited June 2009
    Ive had the older Bic-H100 for over a year now and have had zero problems with it, sounds real good to me and also has high WAF. Altho the nerwer version doesnt come in piano black
  • svtjoe
    svtjoe Posts: 55
    edited June 2009
    The Bics have good ratings, but arn't they only 150watts RMS? It would be nice to see a 300rms unit.
