break-in period
Ruune
Just installed some MM100s and MM465s, and I plan on spending a week breaking them in... is this sufficient? What is the recommended time in break-in hours?
thanks,
Ruune
thanks,
Ruune
Post edited by Ruune on
i usually give 40 to 50 hours break-in time. depending on the situation. just allow ample time for what you plan on doing.:D
thanks,
Ruune
hey ruune you are the same ruune from f150 online right? -
